[Qgis-user] QGIS3 Processing Clip
Andreas Neumann a.neumann at carto.net
Fri Mar 23 04:53:15 PDT 2018
Hi Peter,
You can find this setting in "Settings" --> "Options" --> "Processing"
--> "General" --> "Invalid features filtering".
However, it is probably more advisable to fix the geometry errors, if it
is feasible. The "Geometry checker" core plugin can help with this task.
Greetings,
Andreas
On 2018-03-23 11:30, Drexel Peter wrote:
> Hi all,
> In QGIS 3.0 I use native:clip in processing to clip a Shapefile with another shapefile.
> The Import-Shapefile contains some invalid polygons so I get an error
> ________
> Processing algorithm…
> AlgorithmDialog
> Input parameters:
> { 'INPUT' : 'V:/Geodaten/Wasser/Einzugsgebiete/Vlbg_Umgebung/Einzugsgebiete_FGW/ezg_gesamt1_bearbeitet_3D_name.shp', 'OVERLAY' : 'C:/temp/QGIS3/Clip-Maske.shp', 'OUTPUT' : 'memory:' }
> Feature (0) has invalid geometry. Please fix the geometry or change the Processing setting to the "Ignore invalid input features" option.
> Execution failed after 0.35 seconds
> Loading resulting layers
> Algorithm 'Clip' finished
> ______________
> In the Log-section of the Clip-Tool.
> But where can change the setting to "Ignore invalid input features"?
> Thanks
> Peter
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180323/1fcf2bb0/attachment.html>
