[Qgis-user] QGIS3 Processing Clip
Drexel Peter Peter.Drexel at vorarlberg.at
Fri Mar 23 05:30:08 PDT 2018
Thanks to both for the answers,
It works now.
Sadly I have to accept the geometry errors at the moment, otherwise I would have to fix hundreds of 3. party-files…
Greetings,
Peter
______________________________________________
Mag. Peter Drexel
Landesamt für Vermessung und Geoinformation<http://vogis.cnv.at/atlas3/init.aspx?hotspot=digitaler_atlas_vorarlberg%7cbasiskarten_und_bilder%7c1%3a1843%7c-55745.5870030623%7c233293.767395111%7chotspot0.gif%7cLandesamt+f%u00fcr+Vermessung+und+Geoinformation>
Johannitergasse 6 A-6800 Feldkirch
Tel: +43(0)5522/75482-60222, Fax: +43(0)5522/75482-6
E-Mail: peter.drexel at vorarlberg.at<mailto:peter.drexel at vorarlberg.at>, http://www.vorarlberg.at/lva
Rechtsverbindlichen Schriftverkehr (z.B. Anträge Rechtsmittel) richten Sie an:
E-Mail: landesvermessungsamt at vorarlberg.at<mailto:landesvermessungsamt at vorarlberg.at>, Fax: +43(0)5522/75482-6
Von: Andreas Neumann [mailto:a.neumann at carto.net]
Gesendet: Freitag, 23. März 2018 12:53
An: Drexel Peter
Cc: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] QGIS3 Processing Clip
Hi Peter,
You can find this setting in "Settings" --> "Options" --> "Processing" --> "General" --> "Invalid features filtering".
However, it is probably more advisable to fix the geometry errors, if it is feasible. The "Geometry checker" core plugin can help with this task.
Greetings,
Andreas
On 2018-03-23 11:30, Drexel Peter wrote:
Hi all,
In QGIS 3.0 I use native:clip in processing to clip a Shapefile with another shapefile.
The Import-Shapefile contains some invalid polygons so I get an error
________
Processing algorithm…
AlgorithmDialog
Input parameters:
{ 'INPUT' : 'V:/Geodaten/Wasser/Einzugsgebiete/Vlbg_Umgebung/Einzugsgebiete_FGW/ezg_gesamt1_bearbeitet_3D_name.shp', 'OVERLAY' : 'C:/temp/QGIS3/Clip-Maske.shp', 'OUTPUT' : 'memory:' }
Feature (0) has invalid geometry. Please fix the geometry or change the Processing setting to the "Ignore invalid input features" option.
Execution failed after 0.35 seconds
Loading resulting layers
Algorithm 'Clip' finished
______________
In the Log-section of the Clip-Tool.
But where can change the setting to “Ignore invalid input features”?
Thanks
Peter
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180323/d2a14678/attachment.html>
