[Qgis-user] clipping csv data to shapefile
Steve Research
stevesteveresearch at gmail.com
Mon Mar 26 23:54:34 PDT 2018
Thanks Alexandre,
I have tried that but it is odd. I have plant world distribution data (lat and long) in a csv which I have as a WGS84 vector layer. I have a European shp file which is converted to WGS84. If I clip the world data layer to the Europe shp I end up with a new, but blank, vector layer.
Cheers
Steve
> On 26 Mar 2018, at 22:25, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Hi Steve,
> In the processing toolbox search for clip.
> set the csv as the input layer, and the world ?countries? shapefile as clip layer.
> Hope it helps
> Steve Research <stevesteveresearch at gmail.com> escreveu no dia segunda, 26/03/2018 às 21:31:
>> I have some plants distribution data (from GBIF) in CSV format.
>> I added this to my world map shapefile (Layer\Add Layer\Add Delimited Text layer).
>> Some records are outside of the coastline.
>> How can I clip this CSV data to the coastline?
>> Regards,
>> Steve
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180327/b16f0df8/attachment.html>
