[Qgis-user] GDAL processing scripts not working on QGIS3 (mac)
Ujaval ujaval at gmail.com
Wed Mar 28 21:31:14 PDT 2018
Thanks. That worked for me as well!
-Ujaval
On Wed, Mar 28, 2018 at 7:07 PM, William Kyngesburye <woklist at kyngchaos.com>
wrote:
> It looks like a PATH problem - there used to be a configuration to set the
> GDAL tools path, but it's missing in QGIS 3, though there is still a
> preference setting saved.  Someone independently found the same workaround
> I did:
> On Mar 26, 2018, at 7:01 PM, dschneiderch <dschneid at gmail.com> wrote:
> I also had this problem and came here looking.
> Here is what worked for me:
> Go to OPtions... System ... Environment
> Enable "Use Custom Variables "
> First select "Prepend", under variable enter "PATH", under value enter
> "/Library/Frameworks/GDAL.framework/Programs:/Library/
> Frameworks/Python.framework/Versions/3.6/bin:"
> (all these without the quotes)
> On Mar 28, 2018, at 2:36 AM, Ujaval <ujaval at gmail.com> wrote:
> Thanks Ken. Looking forward to the fix.
> On Tue, Mar 27, 2018 at 9:39 PM, knussear <knussear at mac.com> wrote:
>> I saw this note on the KyngChaos main page - the last line indicates to me
>> that William is looking into it
>> QGIS 3.0.0-3
>> QGIS 3.0.0-3 should fix the non-working GRASS problem. The key was my
>> adding
>> the "3" to the app name with a space, the GRASS internals didn't like
>> that.
>> So I removed the space - it's now QGIS3.app. The installer removes the
>> contents of the original QGIS 3.app, but not the app folder itself, so you
>> need to delete that from your Applications folder.
>> It also looks like the rebuild fixed the missing SAGA processing tools.
>> On to figuring out why GDAL tools do not work…
>> 2018/03/22 07:31
>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> [Trillian]  What are you supposed to do WITH a maniacally depressed robot?
> [Marvin]  You think you have problems?  What are you supposed to do if you
> ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000
> times more intelligent than you and even I don't know the answer...
> - HitchHiker's Guide to the Galaxy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180329/2261ec2c/attachment.html>
