[Qgis-user] Batch "ECW creating"
st_kiefer at web.de
st_kiefer at web.de
Tue Apr 16 04:42:43 PDT 2019
sorry, I did not carefully read .. obviously the wrong answer. But as far as I understand you need a valid ERDAS license for compression.
Cheers.
Stefan
> st_kiefer at web.de hat am 16. April 2019 um 12:46 geschrieben:
> you might want to have a look for
> https://gdal.org/frmt_gtiff.html
> search for "COMPRESS=" and decide which compression mode to use, and further parameter if posiible to control the compression level like for example "JPEG_QUALITY=", to extend the -co parameter.
> Cheers.
> Stefan
> > > Piotr Kania <p.kania00 at gmail.com> hat am 16. April 2019 um 12:32 geschrieben:
> > Hello!
> > I am sorry for asking about sth not connected with qgis...
> > I would like to use old FWTools 2.4.7 to convert geotiff's files to ecw format. Right now I use that "command": for %i in ("d:\....\*.tif") do gdal_translate -of ECW -co LARGE_OK=YES "%i" "d:\.....\%~ni.ecw
> > Can I add sth to that "command" to achieve better "compression ratio"? Thanks for any response.
> > Greetings - Piotrek
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190416/d359d7db/attachment-0001.html>
