[Qgis-user] PIN # LookUp Help?
Philip Barlow philipb at pembrokeshirecoast.org.uk
Tue Feb 19 02:41:07 PST 2019
Hi Craig,
There are various ways to answer question 1 but probably the easiest is to use locator, if you are using QGIS 3.x you’ll see a little search box in the bottom left hand corner. Try entering you pin into that, if you don’t get any search results you may have to enable some additional locator filters from settings>options>locator.
Other ways including selecting with an expression or using a plugin like “search layers” (https://github.com/NationalSecurityAgency/qgis-searchlayers-plugin).
In answer to your second question my guess would be that you use metasearch to add the tax record data as WFS and then join the layers together based on the id or do a spatial join? I don’t know the dataset so I can only speculate.
Hope that helps.
Phil Barlow
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Craig C. Horvath
Sent: 18 February 2019 19:16
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] PIN # LookUp Help?
Hello,
This site, that is located/used by Will County Illinois:
https://gisapp.willcountyillinois.com/Html5Viewer/Index.html?viewer=Data_Viewer
If you type in a PIN in the search box, you can go directly to the parcel:
11-04-34-210-002-0000
Once you get to the parcel, you can then Look up Tax records information, etc.
I have utilized the County database tools to create my own QGIS map.  I have utilized all of the datasets.  However, I am unable to do the following:
1) In my map, I am unable to type in Addresses or PINS in order to Go Directly To a specific parcel.  I have to move the map around until I find it.    How do you use a Find function to type in an address or PIN to go directly to the parcel?
2) The County has stated that I should be able to use "Meta Search' functionality in order to be able to see Tax Records information from my Qgis map, similar to the same fashion that the County site works.  Would anyone now how I can link up the data somehow in order to do this?
Craig
Mae'r Awdurdod yn hapus i gyfathrebu yn Gymraeg neu yn Saesneg
The Authority is happy to communicate in Welsh or English
Website www.pembrokeshirecoast.org.uk
Follow us on Twitter
Join us on Facebook
Watch us on Youtube
Look at us on Flickr
This email and any attached files should only be read by those persons to whom
they are addressed and be used by them only for their intended purpose.
If you are not the intended recipient please destroy all copies and inform the
sender by return email.
Please note that the contents of this email may be subject to public disclosure
under the Freedom of Information Act 2000 and therefore the confidentiality of
this message and any reply cannot be guaranteed.
Click here to view PCNPA Privacy Notice – Keeping your Information Safe
For further information on the PCNPA please visit our website at www.pembrokeshirecoast.org.uk
Please consider the environment before printing this email.
Dim ond y personau hynny yr anfonwyd yr e-bost hwn atynt ac unrhyw ffeiliau sydd
ynghlwm ddylid eu darllen, a dim ond hwy ddylid eu defnyddio at y diben y bwriadwyd hwy.
Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech gystal â dinistrio pob copi a rhoi
gwybod i'r anfonwr gyda throad yr e-bost.
Noder os gwelwch yn dda y gall cynnwys yr e-bost hwn orfod cael ei ddatgelu i'r cyhoedd o
dan Deddf Rhyddid Gwybodaeth 2000 ac felly ni ellir gwarantu cyfrinachedd y neges hon
nac unrhyw ateb.
Cliciwch yma i weld Hysbysiad Preifatrwydd APCAP - Cadw eich Gwybodaeth yn Ddiogel
Am ragor o wybodaeth am APCAP ymwelwch â'n gwefan ar www.arfordirpenfro.org.uk
Ystyrier yr amgylchedd cyn argraffu'r e-bost hwn os gwelwch yn dda.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190219/7746719e/attachment.html>
