[Qgis-user] Export to DXF question
Johanna Botman
johannab at melton.vic.gov.au
Sun Feb 24 20:19:24 PST 2019
I am trying to use the Export to DXF function in QGIS 3.2 without satisfaction.
The layer that I want to export is a layer of polygons representing a Property layer. I want to export the House number as a label associated with each polygon. I tick the Export with Mtext box - after making sure that my layer is labelled with the attribute that I want. I select that I want my layer symbology and I choose my required attribute from the Output Layer Attribute.
Only 30 of the 300 or so labels are exported to the DXF file. When I open the DXF in AutoCAD I can select those 30 labels but cannot change the size of the font.
What do I need to do to make sure that I have all the labels for my layer?
I asked the question on GIS Stack Exchange last week without much luck in obtaining an answer.
Johanna Botman
Asset & GIS Officer | Melton City Council
The information in this message is privileged and confidential, intended only for the use of the individual or entity named above. If you are not the intended recipient you are hereby notified to delete the message and that any dissemination, copying or use of its content is strictly prohibited. If you have received this message in error please notify the Melton City Council.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190225/d1c19c99/attachment.html>
