[Qgis-user] change default webbrowser in qgis3 settings?
Richard Duivenvoorde rdmailings at duif.net
Mon Feb 25 13:08:29 PST 2019
Hi Jeroen,
I'd say: create an issue in the repo of it:
https://github.com/tomchadwin/web2qgis/issues
I have some plugins which opened an url or file in a browser, and then
used default Qt-machinery, something like:
QDesktopServices.openUrl('http://qgis.org')
What happens if you use that in the Python Console? In your QGIS 3.
Does it open your preferred browser?
Or does it also open IE. If last, then maybe it is a Qt setting?
Regards,
On 25/02/2019 09.43, Groene Bij wrote:
> Hi all,
> I am sorry to repeat this question. I really hope someone can help.
> Today I did a clean install of 3.4.5 and exporting a map with the plugin
> qgis2web it still opens the webmap in IE. I don’t use IE, haven’t
> configured it and it is not my default webbrowser in Win10.
> Somehow, some setting in qgis 3 doesn’t use my default windows settings
> correctly.
> Qgis 2.18.28 doesn’t have this problem. I also did a clean install of
> 2.18.28 today, exported a map with the plugin and it opens in my default
> webbrowser which is Firefox.
> Is it a bug in 3.4.5?
> Is there a setting somewhere to change the webbrowser used?
> Gr.
> Jeroen
> *Van:*Qgis-user <qgis-user-bounces at lists.osgeo.org> *Namens *Groene Bij
> *Verzonden:* maandag 11 februari 2019 17:10
> *Aan:* qgis-user at lists.osgeo.org
> *Onderwerp:* [Qgis-user] qgis3 uses IE as default browser on windows10?
> Hi,
> Is there a setting in qgis3 to change the default internet browser used
> by processes?
> For instance, qgis2web opens a webbrowser after exporting the webmap. In
> qgis2.18 my default browser Firefox was opened. Now, qgis3.4.4 it opens IE.
> According to Tom Chadwin (qgis2web) the plugin refers to a piece of
> Pyhton code when opening the webbrowser:
> The code which opens the browser when you export is:
> https://github.com/tomchadwin/qgis2web/blob/master/qgis2web/maindialog.py#L342
> It uses the Python webbrowsermodule:
> https://docs.python.org/3/library/webbrowser.html
> I have no experience with pyhon, so I hope there is a setting somewhere
> to choose my default browser. Besides that, I do hope qgis3 will simply
> follow the default settings from the OS.
> Kind regards.
> Qgis-user mailing list
