[Qgis-user] gdal_rasterize settings
john polo jpolo at mail.usf.edu
Mon Feb 25 16:32:31 PST 2019
Dear List,
I'm using gdal_rasterize in QGIS 3.4.4. The GDAL version is 2.4.0. I
have a vector of the state of Oklahoma that I am trying to convert to a
raster. I am using the Rasterize command from the Processing Toolbox. I
want to set the Output Raster Size Units to use Georeferenced units (30m
x 30m). The vector is projected to UTM 14. In the command window, I can
not figure out how to set the Width/Horizontal resolution to
"30.0,30.0". I've tried this command several times and each time, I
can't set the resolution to anything but one value, 30. The GDAL/OGR
console call at the bottom the Rasterize window says:
gdal_rasterize -l ACS2016 -a density -tr 30.0 0.0 -a_nodata 0.0 -te
141482.98459323175 3728541.225561033 918798.5521893443
4103736.2372529646 -ot Float32 -of GTiff
D:\projects_and_data\GIS\r_msis\ACS2016.shp
C:/Users/s/AppData/Local/Temp/processing_bd713baa4f114400804f771fe874c9c5/dda5be259b534b75a2e87994501110cd/OUTPUT.tif
The same error:
ERROR 1: Wrong value for -tr parameter.
I can't manually edit this in the window and I'm not sure how else to
run this command with the right settings.
John
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190225/8e2d8e3f/attachment.html>
