[Qgis-user] EPSG:
Andreas Neumann a.neumann at carto.net
Sun Jul 28 22:51:52 PDT 2019
EPSG:3857 is not using degrees. It is a meter based coordinate system
with very high distortions, esp. towards the poles. That's why it is
only useable up to 85 degrees north and south. The max projected bounds
are:
-20026376.39 -20048966.10
20026376.39 20048966.10
See also http://epsg.io/3857
Of course one can always transform the EPSG:3857 meter based coordinates
back to degrees.
Andreas
On 2019-07-29 01:01, qgis-user at stripfamily.net wrote:
> The coordinates in my map seem to make no sense when I use EPSG:3857   ,
> WGS84 pseudo mercator.
> Here are the extents as displayed in the status bar:
> -11905442.9,4361690.4 : -11899117.1,4365315.2
> Here are the same extents in EPSG:4326 - -106.9,36.4 : -106.9,36.5.
> These are what I'd expect
> I thought EPSG:3857 used degrees - ie, +/-180°, +/- 85°
> QGIS 3.6.0
> Thanks
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190729/8baf59e9/attachment.html>
