[Qgis-user] Problems building QGIS: segmentation fault Python plugins
Hernán De Angelis dhdeangelis at comhem.se
Fri Jun 7 04:42:44 PDT 2019
Hello QGIS'ers
I am experiencing consistent problems when building the latest qgis
(3.6.3) in a fresh openSUSE 15.1 installation. There seems to be some
trouble with python plugins (see below) and I cannot find the cause of
these problems. These errors are preceeded by a large number of warnings
of the sort:
//usr/local/src/qgis-3.6.3/build/python/core/sip_corepart1.cpp:342269:105:
warning: dynamic exception specifications are deprecated in C++11
[-Wdeprecated]//
// ":param center: Center point.\n" //
What's going on here? Does anyone have a hint?
Thanks in advance
H.
[ 80%] Built target pygui
Generating pyqgis api file
[ 81%] Generating ui_DlgVersioning.py
[ 81%] Generating ui_DlgAddGeometryColumn.py
[ 81%] Built target qsci-api
[ 81%] Generating ui_console_compile_apis.py
make[2]: ***
[python/plugins/db_manager/db_plugins/postgis/plugins/versioning/CMakeFiles/zzz-db_manager-5-depend.dir/build.make:63:
python/plugins/db_manager/db_plugins/postgis/plugins/versioning/ui_DlgVersioning.py]
Segmentation fault (core dumped)
make[1]: *** [CMakeFiles/Makefile2:4212:
python/plugins/db_manager/db_plugins/postgis/plugins/versioning/CMakeFiles/zzz-db_manager-5-depend.dir/all]
Error 2
make[1]: *** Waiting for unfinished jobs....
[ 81%] Generating ui_console_history_dlg.py
make[2]: ***
[python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/build.make:74:
python/plugins/db_manager/ui_DlgAddGeometryColumn.py] Segmentation fault
(core dumped)
make[1]: *** [CMakeFiles/Makefile2:3683:
python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/all]
Error 2
[ 81%] Generating ui_console_settings.py
make[2]: *** [python/console/CMakeFiles/pyconsole.dir/build.make:63:
python/console/ui_console_compile_apis.py] Segmentation fault (core dumped)
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [python/console/CMakeFiles/pyconsole.dir/build.make:67:
python/console/ui_console_history_dlg.py] Segmentation fault (core dumped)
make[2]: *** [python/console/CMakeFiles/pyconsole.dir/build.make:71:
python/console/ui_console_settings.py] Segmentation fault (core dumped)
make[1]: *** [CMakeFiles/Makefile2:6372:
python/console/CMakeFiles/pyconsole.dir/all] Error 2
[ 98%] Built target qgis_app
make: *** [Makefile:152: all] Error 2
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190607/88dcbfaa/attachment.html>
