[Qgis-user] Layer definition file
Áron Gergely aron.gergely at rasterra.nl
Wed Jun 26 11:30:04 PDT 2019
Hi Antal,
Yes, it is possible to save the styling of the layer in a GeoPackage.
And to me it seems like it works the same as in QGIS 3.6.
Here is a walkthrough:
Suppose you have a vector layer in a GeoPackage that you opened in QGIS,
you styled it and now you want to save that style:
In the layer tree window, right click on the layer -> properties.
Click the "Symbology" tab and go to the bottom of the window, click on
Style -> Save style...
A new window will pop up with a roll-down menu "Save Style" on top.
there you should select "In Database (GeoPackage)"
You can then input a name and the description (optional) for the style
you are saving.
Also, if you tick on "save as default style" QGIS will automatically
style that layer accordingly whenever (and whatever machine) you open
that layer from the GeoPackage.
Once happy, click OK and that should be it.
If you inspect the geopackage afterwards you will see that there is a
new table called "layer_styles"
where the styling is saved in both QML and SLD, in the correspondingly
named fields.
Cheers,
Áron
On 26/06/2019 04:58, kosza.antal wrote:
> Hi everyone,
> There is a way, to store the layer definition file in geopackage, with
> qgis 3.8?
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190626/f0559fb6/attachment.html>
