[Qgis-user] Using 3D map views with python console or in an atlas
Ryan Brook (Perth) Ryan.Brook at advisian.com
Sat Jun 29 01:47:16 PDT 2019
We have made some videos using frames exported from a 3D map view.
We are not able to use the animation function within the 3D map as our camera is static and we are changing the visibility preset between each frame to load in a different time step.
Are any of the 3D map view capabilities exposed and useable from the QGIS python console? From some Google searches I could not find any discussion or documentation on the topic.
Our preferred workflow would be to be able to use the 3D map within an atlas so that we can add text and other items to the view (we are post processing the images to add this), however it does not appear that 3D views can be used with data defined overrides at this time.
Any direction you can provide would be appreciated as it is quite a manual process to export a reasonable number of frames to stitch together into a video.
Regards,
Ryan
*** Advisian Notice *** "This email is confidential. If you are not the intended recipient, you must not disclose or use the information contained in it. If you have received this email in error, please notify us immediately by return email and delete the email and any attachments. Any personal views or opinions expressed by the writer may not necessarily reflect the views or opinions of any company in the WorleyParsons Group of Companies. How we use your personal data: http://www.advisian.com/en-us/who-we-are/privacy-policy /SPAN>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190629/fa283c2b/attachment.html>
