[Qgis-user] georeference plugin not working
damien stephens damien.stephens at gmail.com
Thu May 2 01:52:43 PDT 2019
I managed to fix it.
Went to:
Settings/options/advanced
Then
Plugin-georeferencer/window/pos
And changed the value to (100,100)
I also changed
Plugin-georeferencer/config/minimise to false
It worked after that.
Cheers
On Wed, 1 May 2019, 10:43 Nicolas Cadieux, <nicolas.cadieux at archeotec.ca>
wrote:
> Hi,
> Could this be a change in QGIS 3.6?
> https://qgis.org/en/site/forusers/visualchangelog36/index.html#feature-new-option-to-avoid-minimizing-georeferencer-when-adding-points
> Le 30 avr. 2019 à 21:16, damien stephens <damien.stephens at gmail.com> a
> écrit :
> Hi.
> I am on qgis 3.6.
> I have been using the referencing plugin for a while with no dramas, but
> now when I click on the tool button in the raster menu, qgis loses focus,
> but the georeferencer window does not appear.
> Have Googled an answer but they are all for qgis v2 and the registry keys
> they recommend changing  are different.
> My qgis 2.18 copy runs georeferencer fine.
> Any help much appreciated.
> Damien
> On Mon, 29 Apr. 2019, 01:35 Tulika Biswas, <teentulika at gmail.com> wrote:
>> I have an issue with using the georeferencer.My problem is after adding
>> co ordinates to the map and giving the transformation settings.. I am
>> running the georeferencing option.. Then it is being displayed on the
>> screen as
>> "Failed to compute GCP points." and the map is also not being shown in
>> the qgis interface..
>> Plz  help.. Its very urgent..
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190502/45dfdea8/attachment.html>
