[Qgis-user] Load Postgis Layer with Blob and use the form widget for binary fields (QGIS 3.6)
Stefan Giese Stefan.Giese at wheregroup.com
Thu May 2 02:41:44 PDT 2019
I have tried to load a postgis layer containing a binary data field
(blob, bytea) and then use the new form widget for binary fields. The
problem is, that the binary field will not be in the layers attribute
table, so the widget can not be used. In the qgis database manager the
field is visible in the table preview. Does anybody knows what is going
wrong or what I am missing?
thanks in advance
stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
