[Qgis-user] problems with raster (merge, clip) and crash dumped
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Tue May  7 08:18:35 PDT 2019
QGIS 2.18 is getting old but is does work well... I would consider updating.  Crash dumps in 2.18 were often in that version.  I believe the usual  course of action is to look at plugins that could cause the crash when QGIS is shut down.  I got tired of that problem so I basically ignored it.
I would first look at the name of the file in case you have Latin characters like ñ or spaces in the file name or file path.   You could try setting Windows locals to US English to see if that changes something but the problem is probably the file name and path.
Nicolas
> Le 7 mai 2019 à 09:56, Azzurra Lentini <lentini.azzurra at polymtl.ca> a écrit :
> Hi to all,
> I am using for my Bachelor classes in university  qgis 2.18 but some of my students have the  problems below.
> They even format the computer completely and the reinstall windows 10 + the softwarer qgis (they even tried different versions of Qgis  2.18) but they still have these problems (I never had these problems in my computers with the same versions of Qgis and with other versions).
> In the new version of QGIS is better but still (in the same computers)  as well as is in my computer with the same versions (for example the merge is not perfect because the file are still separated! so I dont think is a problem of which version they use.
> ERRORS:
> When they upload files RASTER with extension  .asc they have the yellow message: Python error: an error has occurred while executing Python code
> They can see well the file .asc in the project but they can not do MERGE  and CLIP.
> MERGE
> Normally they try to do the Merge of different ASC files with Raster/Miscellaneous/Merge and the error message is:
> error 4C... no such file
> Normally they try to do the clip of raster files .TIFF from Raster/Extraction/CLIPPER and the error message is:
> "ascii" codec cant encode character u'/xe0' in position 60: ordinal not in range (128) ...
> So I don't understand what can I do, because they have also formatted and cleaned the computers and in my computer and in some other computers everything is fine with the same versions and commands.
> Another problem that is also in some other computers is that when they exit from the project, they have this error message (that close the project without saving):
> CRASH DUMPED : minidump written to C ...
> Thank you for any suggestion.
> Azzurra
> Qgis-user mailing list
