[Qgis-user] Unable to find driver ECW and JP2ECW
Reginald Reginald.Carlier at ingelmunster.be
Fri May 10 01:37:00 PDT 2019
Hi list,
I have a qgis server project in which I serve several tiffs. It used to work
fine but after updating to the latest version of QGIS 3 and QGIS 3 server it
fails.
When trying to connect via the Data Source Manager I get this error:
Het downloaden van capabilities is mislukt:
Downloaden van capabilities mislukt: Error transferring
http://localhost/cgi-bin/qgis_mapserv.fcgi.exe?MAP=Projecten/Waterlopen/Waterlopen.qgz&VERSION=1.3.0&SERVICE=WMS&REQUEST=GetCapabilities
- server replied: Internal Server Error
The Apache log shows:
[Thu May 09 08:56:15.589184 2019] [cgi:error] [pid 2712:tid 1628] [client
::1:60271] AH01215: Warning 1: Unable to find driver ECW to unload from
GDAL_SKIP environment variable.:
C:/OSGeo4W64/apps/qgis/bin/qgis_mapserv.fcgi.exe
::1:60271] AH01215: Warning 1: Unable to find driver JP2ECW to unload from
It is kind of strange because other projects in which I serve tiffs are
still working.
When I test the configuration of qgis server everything seems ok but it is
not working.
Regards,
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
