[Qgis-user] Error in the attribute table when you use "dropdown menus (cascade)" in forms
Rafa García Castillo ragaca at gmail.com
Tue May 14 23:04:55 PDT 2019
Hi to all,
I´m using QGIS v3.6 under Windows 10. I have set up several forms using
"dropdown menus (cascade)" for filling up some fields y several layers.
This "dropdown menus (cascade)" mean that each of this menus read their
values from a table with this possible values (domains), using the "value
relation" from QGIS forms set up section. And because it´s in cascade
(using the "current_value()" function), once you select on value in the
first of this dropdown menu, the values showed in the next one is filtered
from the total values that could come from the domain table. And go on for
the rest od these dropdown menus.
Everything works well in the form, but if you look at the attribute table,
the filters in cascade done in the form set up using the "current_value()"
function doesn´t work well, so you are presented values in these fields
that are not correct.
I would like one of these two possible options:
  A) The data in the attribute table is not influenced for the
configuration done in the form section. So you would so the "raw data"
  B) The data in the attribute table shows the same behavior that in the
form, so the filters in cascade would works well.
One of these two options would be ok, but know the data shown in the
attribute table when you have set up "dropdown menus (cascade)" in the form
is incorrect.
Thanks in advance
Rafa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190515/a08f9de7/attachment.html>
