[Qgis-user] QGIS to load spefific OpenStreetMap data
Stefan Keller sfkeller at gmail.com
Wed May 15 12:25:42 PDT 2019
Dear all
Thanks so much for your feedback.
Am Mi., 15. Mai 2019 um 01:24 Uhr schrieb Jorge Gustavo Rocha
<jgr at geomaster.pt>:
> better than using the bounding box. Good point! We can drop the 'shop'
> key and simply write: 'bakery or supermarket in Zurich' in the Wizard.
I do have a final enhancement :-).
On Tue, May 14, 2019 at 3:43 PM Jorge Gustavo Rocha <jgr at geomaster.pt> wrote:
> 7) Add layer to QGIS (eventually points and polygons; calculate
> the centroids for the polygons in QGIS)
After writing e.g. "bakery or supermarket in Uster" into the
Overpass-Turbo wizard, one generates the query.
Then the query can be enhanced by replacing node/way/lines to "nwr"
and "out body; >; out skel qt;" from the output section at the end to
"out center;".
The first is an abbreviation and the second generates nodes from areas.
This is the result I'd like to propose:
[out:json][timeout:25];
{{geocodeArea:Uster}}->.searchArea;
  nwr["shop"="bakery"](area.searchArea);
  nwr["shop"="supermarket"](area.searchArea);
out center;
Yours, Stefan
> Hi,
> Thank you for the feedback, Clifford. Adding the suffix 'in Zurich' is
> Much better!
> Regards,
> Jorge Gustavo
> Às 00:02 de 15/05/19, Clifford Snow escreveu:
> > Stefan,
> > Let me make one suggestion to Jorge's overpass query. By using the
> > Overpass-Turbo Wizard search for shop=bakery or shop=supermarket in
> > Zurich. By adding in Zurich, the query will leave out objects in
> > adjacent cities.
> > From the overpass turbo webpage, export the data as a geojson to load
> > into QGIS. Should work like a charm.
> > Best
> > Clifford
> > <mailto:jgr at geomaster.pt>> wrote:
> >     Hi Stefan,
> >     Às 22:28 de 14/05/19, Stefan Keller escreveu:
> >     > Hi,
> >     > I'm preparing a talk about QGIS and OpenStreetMap for the annual
> >     > meeting of the local QGIS chapter.
> >     > => Question: How do you (users) load specific OSM data into QGIS, like
> >     > for example all bakeries of Zurich? (ways/polygons as centroids?)
> >     I prefer to go to the overpass end point, to show how easy is to extract
> >     OpenStreetMap data. It is faster than installing a plugin.
> >     For a talk, use the overpass Wizard to build the query.
> >     1) Go to http://overpass-turbo.eu/
> >     2) Search for Zurich
> >     3) Open the Wizard
> >     4) Just type: bakery
> >     5) Build and run query
> >     6) Export as GeoJson
> >     7) Add layer to QGIS (eventually points and polygons; calculate the
> >     Good luck for your presentation.
> >     Regards,
> >     Jorge Gustavo
> >     > Background: QGIS 2 had a built in downloader which is gone in QGIS 3.
> >     > This instruction is 4y old [1], and this wiki page seems to be
> >     > outdated too [2].
> >     > I know, that QGIS can read OpenStreetMap XML (.osm) and .PBF files as
> >     > vector layer. And I know about these two plugins: OSMDownloader [3]
> >     > and QuickOSM [4].
> >     > * OSMDownloader requests a bbox from the user, then downloads the
> >     > whole area through the OSM API using the OGR OSM driver.
> >     > * QuickOSM generates queries in outdated Overpass XML, but accepts
> >     > also the newer Overpass QL language, like for example the following:
> >     > [out:xml];
> >     > area[name="Uster"];
> >     >   nwr[shop~"supermarket|bakery"](area);
> >     > out body;
> >     > out skel qt;
> >     > :Stefan
> >     > [1] https://learnosm.org/en/osm-data/osm-in-qgis/
> >     > [2] https://wiki.openstreetmap.org/wiki/QGIS
> >     > [3] https://plugins.qgis.org/plugins/OSMDownloader/
> >     > [4] https://plugins.qgis.org/plugins/QuickOSM/
> >     > _______________________________________________
> >     > Qgis-user mailing list
> >     > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> >     > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >     > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >     Logo*   Geomaster, LDA*
> >       *VENHA DESCOBRIR O CAMINHO DO OPEN SOURCE CONNOSC**O
> >     Avenida Barros e Soares
> >     N.º 423, 4715-214 Braga
> >     VAT/NIF510 906 109
> >     Phone  +351 253 680 323
> >     Site       geomaster.pt <http://geomaster.pt> <http://geomaster.pt>
> >     GPS       41.53322, -8.41929
> >     Jorge Gustavo Rocha
> >     CTO
> >     Mobile  +351 910 333 888
> >     Email    jgr at geomaster.pt <mailto:jgr at geomaster.pt>
> > @osm_washington
> > www.snowandsnow.us <https://www.snowandsnow.us>
> > OpenStreetMap: Maps with a human touch
> VAT/NIF510 906 109
> Jorge Gustavo Rocha
> CTO
