[Qgis-user] Query cross-table "similar" time stamps?
Mike Flannigan mikeflan at att.net
Thu May 16 04:28:56 PDT 2019
I'm thinking this is easier done outside of QGIS, but if you
want to do in within QGIS this is one way:
https://www.qgistutorials.com/en/docs/nearest_neighbor_analysis.html
Mike
On 5/15/2019 1:17 PM, qgis-user-request at lists.osgeo.org wrote:
> Hi folks,
> I'm sure there must be some "easy" solution, but hours of searching
> provided no examples I could learn from to develop a solution:
> I have a point layer of bird observations and a GPS-track recorded while
> observing the birds in an area.
> For the interpretation of the findings it would be good to easily find
> out, from which position the recorded observation was taken.
> My idea was to compare the timestamp of the bird point with the
> timestamps of the track points, but I run into huge obstacles right at
> start:
> I know that I "could" query across layers by the expression aggregate().
> Unfortunately, the docs on that is so sparse, that I have not the
> slightest idea how to even start with that
> (https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/expression.html?highlight=expression#aggregates-functions)
> Ok, in case I could find out how to properly use aggregate, how do I
> best compare those time stamps?
> The layers derive from gpx-files and QGIS identifies the time tag as
> QDateTime.
> As it is not very likely that a bird observation was recorded at the
> exact same time as a track point was generated, there is no way to
> actually compare the values, cause the bird time value will always lie
> in between two track point values.
> What kind of query can be used to identify those two trackpoints ?
> In short: How can I identify/highligt/mark track points that have a
> timestamp close the selected point in another layer?
> I already created a question on this on gis stackexchange with a
> screenshot,but no reactions so far.
> https://gis.stackexchange.com/q/30708/8202
> Thankful for any hint
> Bernd
