[Qgis-user] Plug in offline installation Qgis3.6.2
Gezehagn Gelebo ggelebo at gmail.com
Fri May 17 06:24:58 PDT 2019
You can search and download plugins you need as ZIP file from
https://plugins.qgis.org/. Then select *Install from ZIP* tab in the
Plugins Manager and browse for the downloaded ZIP file to open it. Click on
Install Plugin. Done.
Regards
Gezehagn
On Fri, May 17, 2019 at 1:42 PM Luigi Pirelli <luipir at gmail.com> wrote:
> it is documented in
> https://docs.qgis.org/testing/en/docs/user_manual/plugins/plugins.html
> please refer to documentation
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> * Hire me: http://www.qcooperative.net
> On Fri, 17 May 2019 at 12:40, Luigi Pirelli <luipir at gmail.com> wrote:
>> you can install from zip file... usually you have to donwload the plugin
>> from code repo as zip file, and (if it is well formed to be installed as
>> zip file), you can install from plugin manager
>> regards
>> Luigi Pirelli
>> On Fri, 17 May 2019 at 11:38, jean Lukusa <lukusam at gmail.com> wrote:
>>> Hi all ,
>>> I would like to  know  how  can  I install  manually offline  plugins (
>>> lithology, Usg library, structure )  in Qgis 3.6.2
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190517/e03aa8e1/attachment.html>
