[Qgis-user] Plug in offline installation Qgis3.6.2
jean Lukusa
lukusam at gmail.com
Fri May 17 12:50:05 PDT 2019
Thanks a lot.
Exploration Geologist
+243 812156128(wattsap,imo)
+243 973741744
+243 840367401
Le ven. 17 mai 2019 14:26, Gezehagn Gelebo <ggelebo at gmail.com> a écrit :
> You can search and download plugins you need as ZIP file from
> https://plugins.qgis.org/. Then select *Install from ZIP* tab in the
> Plugins Manager and browse for the downloaded ZIP file to open it. Click on
> Install Plugin. Done.
> Regards
> Gezehagn
> On Fri, May 17, 2019 at 1:42 PM Luigi Pirelli <luipir at gmail.com> wrote:
>> it is documented in
>> https://docs.qgis.org/testing/en/docs/user_manual/plugins/plugins.html
>> please refer to documentation
>> Luigi Pirelli
>> * LinkedIn: https://www.linkedin.com/in/luigipirelli
>> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
>> * GitHub: https://github.com/luipir
>> * Mastering QGIS 2nd Edition:
>> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
>> * Hire me: http://www.qcooperative.net
>> On Fri, 17 May 2019 at 12:40, Luigi Pirelli <luipir at gmail.com> wrote:
>>> you can install from zip file... usually you have to donwload the plugin
>>> from code repo as zip file, and (if it is well formed to be installed as
>>> zip file), you can install from plugin manager
>>> regards
>>> Luigi Pirelli
>>> On Fri, 17 May 2019 at 11:38, jean Lukusa <lukusam at gmail.com> wrote:
>>>> Hi all ,
>>>> I would like to know how can I install manually offline plugins (
>>>> lithology, Usg library, structure ) in Qgis 3.6.2
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190517/ea3d8682/attachment.html>
