[Qgis-user] Unable to launch QGIS with X Forwarding - Can Not make qgis.db private copy
Amedeo Fadini amefad at gmail.com
Sun May 19 02:06:56 PDT 2019
Hi everybody,
I have a ubuntu Bionic LTS server with QGIS 3.4 LTR installed
Since the Qgis project I've published connects to local postggis data I
would like to launch Qgis with X forwarding to modify directly the
published project...
The client is debian 9.8 when I try to launch qgis it shows me the import
esttings window, then the splash screen and after that an alert window with
message "ERROR Can Not make qgis.db private copy" the stdout also log the
following
ERROR: auth db directory path could not be created
ERROR: opening of authentication db FAILED
the auth db path is setted in apache. conf for qgis server: tried to set
the same path as environment variable but no change.
seems that after installation I don't have .qgis3 folder
Any suggestion?
Amedeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190519/9398b6e5/attachment.html>
