[Qgis-user] KMZ
Berger, Stefan (Perth) Stefan.Berger at Advisian.com
Sun May 19 18:57:54 PDT 2019
Hi Lukas,
It is my understanding that KMZ files should always be projected in WGS84, even if your QGIS project is in a different projection.
Hopefully that solves your issue.
Stefan Berger MIEAust
Environmental Engineer
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Lukas Sadler
Sent: Monday, 20 May 2019 9:45 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] KMZ[External Sender]
** [EXTERNAL SENDER] Do not click links or open attachments unless you recognize the sender. **
I've tried importing KMZ files from google earth into a project on QGIS (3.6.3 Noosa) but the files don't project in the same location even if i set it to the project's CRS
what should i do to have the KMZ files projecting in the correct location
*** Advisian Notice *** "This email is confidential. If you are not the intended recipient, you must not disclose or use the information contained in it. If you have received this email in error, please notify us immediately by return email and delete the email and any attachments. Any personal views or opinions expressed by the writer may not necessarily reflect the views or opinions of any company in the WorleyParsons Group of Companies. How we use your personal data: http://www.advisian.com/en-us/who-we-are/privacy-policy /SPAN>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/d5b58dfa/attachment.html>
