[Qgis-user] KMZ
iqnaulhaq at gmail.com iqnaulhaq at gmail.com
Sun May 19 20:10:03 PDT 2019
Hi Lukas,
Make sure that on-the-fly CRS is enabled in QGIS, then set your KMZ layer CRS to EPSG: 4326 first. Let’s see if it’s projected to the correct location.
Muhammad Iqnaul
GIS Specialist
Jakarta, Indonesia
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Lukas Sadler
Sent: Monday, 20 May 2019 9:45 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] KMZ[External Sender]
** [EXTERNAL SENDER] Do not click links or open attachments unless you recognize the sender. **
I've tried importing KMZ files from google earth into a project on QGIS (3.6.3 Noosa) but the files don't project in the same location even if i set it to the project's CRS
what should i do to have the KMZ files projecting in the correct location
*** Advisian Notice *** "This email is confidential. If you are not the intended recipient, you must not disclose or use the information contained in it. If you have received this email in error, please notify us immediately by return email and delete the email and any attachments. Any personal views or opinions expressed by the writer may not necessarily reflect the views or opinions of any company in the WorleyParsons Group of Companies. How we use your personal data: http://www.advisian.com/en-us/who-we-are/privacy-policy /SPAN>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/517f8703/attachment.html>
