[Qgis-user] Fix Geometries
Mithoefer mithoefer at gbd-consult.de
Mon May 20 23:54:08 PDT 2019
Hi Finnbar,
What plugin are you talking about and what QGIS version do you use?
You have a number of tools to check geometries. Try "Topology checker"
or "Geometry checker" to see where the problems are (invalid
geometries). Geometry checker is also able to fix some issues. Maybe
thats the one you use.
Anotehr option is GRASS GIS. Have you ever worked wit GRASS GIS? You can
create a GRASS database and import your polygons. GRASS GIS uses a
topolgical data model and is quite powerful in establishing a desent
data model with snapping options and clean functions. You can also try
GRASS tools from the processing framework like build polygons or clean.
Regards
Klaus
Am 20.05.19 um 11:31 schrieb GILLEN Finbar:
> Hi All,
> I have a few polygon layers where anytime I go to use them I have to use
> the fix geometries plugin so that invalid geometries are fixed.
> When I save the output from the fixed geometries plugin and add it in a
> new project the same issues appears where I can’t use it accurately to
> do a Select or Join by Location because some of the geometries are still
> seen as invalid even though they have been ‘fixed’.
> Is there anyway solution to this or do I have to keep using the fix
> geometries plugin anytime I use the polygons for analysis?
> Regards
> Finbar
> The contents and any attachments of this electronic mail message are
> confidential and intended only for the named addressees. Dissemination,
> forwarding, publication or other use of the message or attachments by
> any unauthorised person is strictly prohibited.
> Unless stated to the contrary, any opinions expressed in this message
> are personal and may not be attributed to AXA Insurance dac or any
> member of the AXA Group of Companies.
> AXA Insurance dac is regulated by the Central Bank of Ireland. For
> business in Northern Ireland, AXA Insurance dac is authorised by the
> Central Bank of Ireland and subject to limited regulation by the
> Financial Conduct Authority. Details about the extent of our regulation
> by the Financial Conduct Authority are available from us on request. AXA
> Insurance dac is a private company limited by shares, registered in
> Ireland number 136155. Registered Office Wolfe Tone House, Wolfe Tone
> Street, Dublin 1.
> "AXA Supporting Road Safety in Ireland"
> Internet e-mails are not necessarily secure. AXA Group does not accept
> responsibility for changes made to this message after it was sent. To
> help promote the use of electronic documents and to be kinder to the
> environment, please consider whether you really need to print this
> email.
> Qgis-user mailing list
