[Qgis-user] Fix Geometries
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue May 21 15:02:20 PDT 2019
The Geometry Checker plugin will add a the 'Check Geometries' option in
the vector menu.  It is very unstable with the current version of QGIS.
If you get it to run, it should solve most problems.  I get it to run
when I only select one test at a time.
The most predictable tool is the vector/geometry tools/Check validity
using the 'QGIS' Method (not GEOS).  That should fix your file.  There
is a 'remove duplicate vertices' and 'delete duplicate geometries' in
processing.  Your problem could also be caused by a module not working
with multipart objects.  Go to vector/Geometry tools/Multiparts to
singleparts.
If your lines don't touch,   try the 'snap Geometries to layer ' in
processing.
Nicolas
On 2019-05-21 2:54 a.m., Mithoefer wrote:
> Hi Finnbar,
> What plugin are you talking about and what QGIS version do you use?
> You have a number of tools to check geometries. Try "Topology checker"
> or "Geometry checker" to see where the problems are (invalid
> geometries). Geometry checker is also able to fix some issues. Maybe
> thats the one you use.
> Anotehr option is GRASS GIS. Have you ever worked wit GRASS GIS? You
> can create a GRASS database and import your polygons. GRASS GIS uses a
> topolgical data model and is quite powerful in establishing a desent
> data model with snapping options and clean functions. You can also try
> GRASS tools from the processing framework like build polygons or clean.
> Regards
> Klaus
> Am 20.05.19 um 11:31 schrieb GILLEN Finbar:
>> Hi All,
>> I have a few polygon layers where anytime I go to use them I have to
>> use the fix geometries plugin so that invalid geometries are fixed.
>> When I save the output from the fixed geometries plugin and add it in
>> a new project the same issues appears where I can’t use it accurately
>> to do a Select or Join by Location because some of the geometries are
>> still seen as invalid even though they have been ‘fixed’.
>> Is there anyway solution to this or do I have to keep using the fix
>> geometries plugin anytime I use the polygons for analysis?
>> Regards
>> Finbar
>> The contents and any attachments of this electronic mail message are
>> confidential and intended only for the named addressees.
>> Dissemination, forwarding, publication or other use of the message or
>> attachments by any unauthorised person is strictly prohibited.
>> Unless stated to the contrary, any opinions expressed in this message
>> are personal and may not be attributed to AXA Insurance dac or any
>> member of the AXA Group of Companies.
>> AXA Insurance dac is regulated by the Central Bank of Ireland. For
>> business in Northern Ireland, AXA Insurance dac is authorised by the
>> Central Bank of Ireland and subject to limited regulation by the
>> Financial Conduct Authority. Details about the extent of our
>> regulation by the Financial Conduct Authority are available from us
>> on request. AXA Insurance dac is a private company limited by shares,
>> registered in Ireland number 136155. Registered Office Wolfe Tone
>> House, Wolfe Tone Street, Dublin 1.
>> "AXA Supporting Road Safety in Ireland"
>> Internet e-mails are not necessarily secure. AXA Group does not
>> accept responsibility for changes made to this message after it was
>> sent. To help promote the use of electronic documents and to be
>> kinder to the environment, please consider whether you really need to
>> print this
>> email.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
