[Qgis-user] Rogue start menu shortcut
Alexandre Neto senhor.neto at gmail.com
Thu May 23 04:34:06 PDT 2019
Hi Paul,
Are you using Windows 10? I have seen that happen on a Windows 10 VM. The
good part is that it's not related to QGIS installer, it's something
Windows creates (like a recently used program). The bad part is that I was
not able to avoid it... :-(
Cheers,
Alex
On Thu, May 23, 2019 at 12:13 PM Paul Wittle <
paul.wittle at dorsetcouncil.gov.uk> wrote:
> Hi,
> My install of QGIS 3 (LTR) keeps adding a shortcut to the start menu every
> time I load the application. I can literally delete the shortcut then open
> QGIS and watch it create the icon again.
> Does anyone know how to stop it doing this; it is frankly just annoying
> when applications change the start menu on load rather than keeping that
> short of thing to the installer?
> I already have the shortcuts I need so this is just adding back a
> duplicate entry I can’t remove.
> Thanks,
> Paul
> This e-mail and any files transmitted with it are intended solely for the
> use of the individual or entity to whom they are addressed. It may contain
> unclassified but sensitive or protectively marked material and should be
> handled accordingly. Unless you are the named addressee (or authorised to
> receive it for the addressee) you may not copy or use it, or disclose it to
> anyone else. If you have received this transmission in error please notify
> the sender immediately. All traffic may be subject to recording and/or
> monitoring in accordance with relevant legislation. Any views expressed in
> this message are those of the individual sender, except where the sender
> specifies and with authority, states them to be the views of Dorset
> Council. Dorset Council does not accept service of documents by fax or
> other electronic means. Virus checking: Whilst all reasonable steps have
> been taken to ensure that this electronic communication and its attachments
> whether encoded, encrypted or otherwise supplied are free from computer
> viruses, Dorset Council accepts no liability in respect of any loss, cost,
> damage or expense suffered as a result of accessing this message or any of
> its attachments. For information on how Dorset Council processes your
> information, please see www.dorsetcouncil.gov.uk/416433
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190523/d5b050ed/attachment.html>
