[Qgis-user] Rogue start menu shortcut
Paul Wittle paul.wittle at dorsetcouncil.gov.uk
Thu May 23 04:43:18 PDT 2019
Yes it is Windows 10 and definitely nothing to do with the installer. The closest I came to tracking it down was that the wintoast module creates a parameter storing a path which is almost right (it actually writes to the user profile but other than that it is the same path) and it also creates a parameter for the file extension *.lnk.
I don’t think it is anything to do with Windows itself as I’m not aware of any other application which does this; it appears to be creating the link as part of the load procedures.
Icons do appear in the recently used section automatically but this is creating a physical file with the extension *.lnk and as far as I can tell; wintoast is the only bit of code which is aimed at Windows users and has the concept of a *.lnk file (shortcut).
Paul
Sent: 23 May 2019 12:34
To: Paul Wittle <paul.wittle at dorsetcouncil.gov.uk>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Rogue start menu shortcut
Hi Paul,
Are you using Windows 10? I have seen that happen on a Windows 10 VM. The good part is that it's not related to QGIS installer, it's something Windows creates (like a recently used program). The bad part is that I was not able to avoid it... :-(
Cheers,
Alex
On Thu, May 23, 2019 at 12:13 PM Paul Wittle <paul.wittle at dorsetcouncil.gov.uk<mailto:paul.wittle at dorsetcouncil.gov.uk>> wrote:
My install of QGIS 3 (LTR) keeps adding a shortcut to the start menu every time I load the application. I can literally delete the shortcut then open QGIS and watch it create the icon again.
Does anyone know how to stop it doing this; it is frankly just annoying when applications change the start menu on load rather than keeping that short of thing to the installer?
I already have the shortcuts I need so this is just adding back a duplicate entry I can’t remove.
Thanks,
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/416433<http://www.dorsetcouncil.gov.uk/416433>
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190523/fb13b11e/attachment.html>
