[Qgis-user] Print Composer Filter
Karl Magnus Jönsson Karl-Magnus.Jonsson at kristianstad.se
Tue May 28 02:46:19 PDT 2019
Ok. One option is to create a rule based style with a filter for the layer. Then add the style as a named style: In the layers symbology tab -> Style button -> Add… and name it e.g. print style. Then make sure all layers are visible and looks like you want in the layout. Add a map theme e.g print theme and associate the map in the layout with this map theme. Then you can change the style in main window as you wish, alter to default style for the layer and remove the rule based styling, make more named styles and map themes for different purposes.
Regards
Karl-Magnus Jönsson
Från: Xan Vieiro [mailto:gallaecia6 at gmail.com]
Skickat: den 28 maj 2019 11:15
Till: Karl Magnus Jönsson
Ämne: Re: [Qgis-user] Print Composer Filter
Hi Karl,
Hi!
How do you mean? You do the filtering in the layer properties in the QGIS main window.
No, I don't. I just want to keep the whole layer at main window and doing filtering directly at print composer.
For atlas there are some more variables or functions available when doing this.
Karl-Magnus Jönsson
Regards,
Xan V.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190528/8c52eead/attachment.html>
