[Qgis-user] Extraction of lineament using Landsat and aster in Qgis. 3.6
jean Lukusa lukusam at gmail.com
Tue May 28 03:29:08 PDT 2019
Hi all.
I want  to  know  the  way  I can  extract  lineaments  and  other
structures  from  landast 8 and  optical aster  using  Qgis version  3.6
Exploration  Geologist
+243 812156128(wattsap,imo)
+243 973741744
+243 840367401
Le mar. 28 mai 2019 10:46, Karl Magnus Jönsson <
Karl-Magnus.Jonsson at kristianstad.se> a écrit :
> Ok. One option is to create a rule based style with a filter for the
> layer. Then add the style as a named style: In the layers symbology tab ->
> Style button -> Add… and name it e.g. print style. Then make sure all
> layers are visible and looks like you want in the layout. Add a map theme
> e.g print theme and associate the map in the layout with this map theme.
> Then you can change the style in main window as you wish, alter to default
> style for the layer and remove the rule based styling, make more named
> styles and map themes for different purposes.
> Regards
> *Karl-Magnus Jönsson*
> *Från:* Xan Vieiro [mailto:gallaecia6 at gmail.com]
> *Skickat:* den 28 maj 2019 11:15
> *Till:* Karl Magnus Jönsson
> *Ämne:* Re: [Qgis-user] Print Composer Filter
> Hi Karl,
> Hi!
> How do you mean? You do the filtering in the layer properties in the QGIS
> main window.
> No, I don't. I just want to keep the whole layer at main window and doing
> filtering directly at print composer.
> For atlas there are some more variables or functions available when doing
> this.
> Regards,
> Xan V.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190528/e4ed562d/attachment.html>
