[Qgis-user] Geophysical Data
C Hamilton adenaculture at gmail.com
Tue May 28 08:48:49 PDT 2019
Grant,
I have worked a little with the SENSYS MAGNETO MX V3 magnetometry array. I
used the AGT toolbox to bring in the data into QGIS and then the SAGA
Inverse Distance Weighted Interpolation algorithm to create an image. I
also wrote a little plugin to visualize the line tracks of each sensor as
well as the envelope of the array for each scan.
I am not 100% sure what your question is. Are you asking to produce a 3D
line for each sensor and be able to plot it? There are several plotting
tools which might be of help. I have not published my magnetometry tools
plugin but it could possibly be expanded to include a 3D version of the
lines with the sensor value be added as a Z value for each point on the
line.
Calvin
On Sun, May 26, 2019 at 8:44 AM Grant Boxer <boxerg at iinet.net.au> wrote:
> I have a data set of located data from a magnetic survey and I am
> wondering if there is a way to plot “stacked profiles” where the magnetic
> values are offset from the flight lines by their value?
> Any suggestions whether this is possible in QGIS/Processing Toolbox?
> Grant Boxer
> Perth, Western Australia
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190528/fad446c8/attachment.html>
