[Qgis-user] Is location info included in metadata when save an image file?
Ert Four 4ert at mailbox.org
Fri May 31 06:32:24 PDT 2019
Thank you, I didn't know SVG was XML/text based, I will check that out.
Sometimes I will need to export a PNG or JPG. Sorry, I need to be really careful, have you or has anyone reading this read the relevant parts of the code, by chance?
For now I'm taking screenshots to be sure nothing is transmitted, but that has limitations.
Thanks.
> On May 30, 2019 at 5:47 PM Alex M <tech_dev at wildintellect.com> wrote:
> On 5/30/19 08:09, Ert Four wrote:
> > Does any coordinate or location data get embedded in the image file if I use Project > Save as Image or Composer > Export as Image/PDF/SVG?
> > I'm using QGIS version 2.14.3 Essen, although I would like to know about more recent versions, too, for when I upgrade later.
> > (I'm aware of the option to check "World file on" and create a separate world file. What I need is to make sure there is no identifying info whatsoever from the project file in the image file itself.)
> > Eg, say I have a basemap like OpenStreetMap open for a country and I load points in another layer that are inside that country. Then I zoom in on a group of points from my data layer, I turn off the basemap layer, and make a map with just my data points. I want to preserve the relative spatial relationships between my points but not reveal where in the world the map came from. If I publish this image file, might the metadata reveal the location?
> > For the work we do, it's critically important we not unknowingly publish specific locations.
> > Thank you, first time posting, very much appreciate QGIS and its community!
> Save Image should be safe for this use if you do not include the world
> file with a png or jpg.
> I believe this is also true for Composer exports to the formats you
> mention, but could easily be checked by exporting and SVG and then
> viewing the SVG (XML) in a text editor.
> Thanks,
> Alex
