[Qgis-user] adding a vertex in the middle of the edge of a polygon
Saulteau Don sault.don at gmail.com
Fri May 31 14:16:30 PDT 2019
I was reading the docs on the Vertex Tool in QGIS 3.6.3.
https://docs.qgis.org/3.4/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#basic-operations
It mentions that to add a new vertex, I simply need to double-click the
line and it will add one using the vertex tool. I can't get it to work
though.
If I double-click this red X (which represents the middle of the segment
between two other vertices), the behaviour I am seeing is that it selects
the phantom middle vertex for me to move it else where (similar to what a
single-click does). I have to "triple" click but that isn't placing the new
vertex exactly in the centre where the imaginary red X is being displayed
to indicate it's the middle of the line. There's no snapping being applied
once it goes into "drag" mode.
I would like to add a vertex at the exact middle of the line where the red
X appears when you hover over it.
How do I add a vertex in the middle of a polyline segment?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190531/42168be8/attachment.html>
