[Qgis-user] Layouts --> Show maps in irregular polygon
Mike Flannigan mikeflan at att.net
Mon Oct 7 15:53:06 PDT 2019
I'm thinking you can make polygons shapes with
holes or islands.  If you do get this done you
will be alternating between clockwise and counter
clockwise nested polygons.
Mike
On 10/7/2019 9:37 AM, qgis-user-request at lists.osgeo.org wrote:
>> Hi Bob,
>> There is a link to unsubscribe below. BTW, I like your idea.  AutoCAD has this.  You could make a feature request in the bug report page.https://www.qgis.org/en/site/getinvolved/development/bugreporting.html
>> By the way, can we make polygons shapes with holes or islands??? If so, you can probably use the transparency to simulate what you need.
> No, there's no way to achieve this properly using current
> functionality. To do it properly we need to ensure that the map
> rendering respects the actual shape of the layout map, and doesn't try
> to place labels or other symbology effects outside of the actual
> visible area.
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191007/d4937f18/attachment.html>
