[Qgis-user] Is there an equivalent to the Mutant plugin for QGIS 3.4.11?
Yann Troutet ytroutet at selkirk.ca
Tue Oct 8 09:26:17 PDT 2019
Thanks Werner,
Problem solved: I forgot to check ' Show also experimental plugins' to find and install it.
Everything works fine.
Yann
>>> Werner Macho <werner.macho at gmail.com> 10/7/2019 11:35 PM >>>
Hi Yann,
Is there any problem with Mutant? Isn't it working any more?
Or are you searching for something else?
regards
Werner
On Mon, Oct 7, 2019 at 10:21 PM Yann Troutet <ytroutet at selkirk.ca> wrote:
I'm trying to easily get spectral signatures from single pixel values using Landsat-8 bands (either a virtual raster, or a band set).
Is there an equivalent for what the Mutant plugin used to do but for the current version of QGIS (3.4.11)?
Yann
This message has been scanned for viruses and dangerous content by
Selkirk College-E.F.A. Project, and is believed to be clean.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191008/f65f5c93/attachment.html>
