[Qgis-user] Is there an equivalent to the Mutant plugin for QGIS 3.4.11?
Werner Macho werner.macho at gmail.com
Tue Oct 8 23:34:56 PDT 2019
Hi Yann
Thanks for your reply.
Yes, the current mutant is only experimental because it was only a "quick"
port to QGIS 3.x.
If you find it can be marked as stable just drop me a not (while I am still
not sure about if everything really works as expected).
Due to illness and heavy workload I am currently not able to improve
stability and do programming work, so you are very welcome to create pull
requests or file issues if you find something.
kind regards
Werner
On Tue, Oct 8, 2019 at 6:26 PM Yann Troutet <ytroutet at selkirk.ca> wrote:
> Thanks Werner,
> Problem solved: I forgot to check ' Show also experimental plugins' to
> find and install it.
> Everything works fine.
> Yann
> >>> Werner Macho <werner.macho at gmail.com> 10/7/2019 11:35 PM >>>
> Hi Yann,
> Is there any problem with Mutant? Isn't it working any more?
> Or are you searching for something else?
> regards
> Werner
> On Mon, Oct 7, 2019 at 10:21 PM Yann Troutet <ytroutet at selkirk.ca> wrote:
>> I'm trying to easily get spectral signatures from single pixel values
>> using Landsat-8 bands (either a virtual raster, or a band set).
>> Is there an equivalent for what the Mutant plugin used to do but for the
>> current version of QGIS (3.4.11)?
>> Yann
>> This message has been scanned for viruses and dangerous content by
>> *Selkirk College-E.F.A. Project*, and is believed to be clean.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191009/a47b3169/attachment.html>
