[Qgis-user] QAD plugin QGIS 2.14.4 - Dimenstion style text layer disabled
gam17 at riseup.net gam17 at riseup.net
Tue Oct 8 23:11:39 PDT 2019
Hi Jochem,
The text layer is a layer that displays labels only. It is a QGIS point
layer with the following characteristics:
1.	the symbol must have a minimum of 90% transparency
2.	must have a label
Please check your layer properties and let me know...
bye
gam17
> Dear,
> I am trying to use the QAD plugin in QGIS 2.14.4 to add dimensions to
> my layers.
> To add dimensions I need to create a dimension style first. For a
> dimension style I need a text layer, a symbol layer and a line layer.
> I created these layers (tables) in PostGIS using the SQL statements
> out of the following document
> (file:///C:/Users/Jochem/.qgis2/python/plugins/qad/help/help_en/index.html#Text%20layer%20model%20for%20dimensioning%3A).
> Next I made a PostGIS connection in QGIS and added the layers
> dim_symbol, dim_line and dim_text. Now I can create my dimension style
> and set the lines on the dim_line layer, the symbols and arrows on the
> dim_symbol layer, but the txt layer stays disabled and I can not
> select the dim_text layer.
> What can be the problem here?
> Met vriendelijke groeten - meilleures salutations
> Jochem Beullens
> CAD & GIS Adviseur
> Consultant CAO & SIG
> +32 (0)3/280 00 57 (#4)
> +32 (0)498/64 81 78
> Geo-IT BVBA - SPRL | BE0867.526.230 | www.geoit.be [1]
> Potvlietlaan 5B - 2600 Antwerpen | Blvd Paepsem 20 - 1070 Bruxelles
> Links:
> [1] http://www.geoit.be/
> Qgis-user mailing list
