[Qgis-user] QGIS 3 - Joins
Burghardt.Scholle at stadt.wolfsburg.de Burghardt.Scholle at stadt.wolfsburg.de
Fri Oct 18 04:04:25 PDT 2019
Hi Karl-Magnus,
thank you for the hint. I'll give it a try again - next week :-).
Burghardt
> -----Ursprüngliche Nachricht-----
> Von: Karl Magnus Jönsson [mailto:Karl-Magnus.Jonsson at kristianstad.se]
> Gesendet: Freitag, 18. Oktober 2019 12:56
> An: Scholle, Burghardt (15-3 GIS); b.j.kobben at utwente.nl; qgis-
> user at lists.osgeo.org
> Betreff: SV: [Qgis-user] QGIS 3 - Joins
> Hi!
> It could work editing views if you set up some triggers or rules for editing the
> view.
> Karl-Magnus
> -----Ursprungligt meddelande-----
> Från: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] För
> Skickat: den 18 oktober 2019 12:09
> Till: b.j.kobben at utwente.nl; qgis-user at lists.osgeo.org
> Ämne: Re: [Qgis-user] QGIS 3 - Joins
> Hi Barend,
> you're right, I know this way and use it a lot as well. Unfortunately I have to
> edit features in this layer and that doesn't work with views.
> Burghardt
> > Von: b.j.kobben at utwente.nl [mailto:b.j.kobben at utwente.nl]
> > Gesendet: Freitag, 18. Oktober 2019 11:53
> > An: Scholle, Burghardt (15-3 GIS); qgis-user at lists.osgeo.org
> > Betreff: Re: [Qgis-user] QGIS 3 - Joins
> > Another way would be to leave the joining up to Postgres, i.e. create
> > a VIEW with the Join and load that view as a layer in QGIS...
> > Barend Köbben
> > On 18/10/2019, 10:16, "Qgis-user on behalf of
> > Burghardt.Scholle at stadt.wolfsburg.de"
> > <qgis-user-bounces at lists.osgeo.org
> > on behalf of Burghardt.Scholle at stadt.wolfsburg.de> wrote:
> >     Dear list,
> >     I have a postgres layer that is connected to other postgres lookup
> > tables via joins. QGIS does not take these joins into account when
> > copying a layer (to another project) or when creating style or layer
> > files. This is really annoying if you have to rebuild the joins by
> > hand over and over again. Am I doing something wrong? In the dialog
> > window "Edit Vector Join" I see no further ways. I only activated the option
> "Cache join layer in virtual memory".
> >     Any hint is appreciated, thanks.
> >     I'm using QGIS LTR 3.4.12
> >     Regards
> >     Burghardt
> >     Stadt Wolfsburg
> >     Geschäftsbereich IT - 15-3 GIS
> >     Rathaus E, Zi. E 313, Porschestraße 47A, D-38440 Wolfsburg
> >     Tel +49 5361 28-2531
> >     Fax +49 5361 28-1765
> >     mailto:burghardt.scholle at stadt.wolfsburg.de
> >     _______________________________________________
> >     Qgis-user mailing list
> >     Qgis-user at lists.osgeo.org
> >     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
