[Qgis-user] Can anybody make v.net.centrality run in Processing?
magerlin MAP at ramboll.dk
Fri Oct 18 10:07:19 PDT 2019
Trying to run v.net.centrality with as many default settings as possible but
it breaks down with:
ERROR: v.net.centrality: Sorry, <points> is not a valid parameter
In other runs I do not get the above error but messages like "WARNING:
Unable to create table <net5dasdafsffd67>"
With small test-data I sometimes get output even with the warnings - If
these result are trustable I do not know.
Running on my full shape file QGIS just hangs: (Not Responding)
Whether QGIS is dead or something is going on I do not know - I will
probably take hours to do the calculation...
Regards Morten
Currently using Qgis 2.18.23 (OSGeo4) and Qgis 3.8.0 in parallel
Windows 7, 64bit
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
