[Qgis-user] Problems using QGIS 3.8 with the 3.4 Training Manual
Alexandre Neto senhor.neto at gmail.com
Wed Oct 30 14:41:07 PDT 2019
Hi Ken,
It can be any of the three problems, but, since you are following orders,
let's assume that it's not your error.
I would start guessing that the documentation may be outdated. And it may
not be a question of 3.4 vs 3.8, but really outdated information even for
3.4.
This being said, can I ask you to open qgis-documentation bug tickets,
whenever you find problems in the documentation?
Thanks,
Alexandre Neto
A quarta, 30/10/2019, 19:18, SIGéal <sigeal at sigeal.com> escreveu:
> Hi,
> I remember having this problem if I typed the shapefile name directly in
> the textbox, without clicking on the Browse button to select a location for
> the file.
> Hope this helps,
> Christophe
> Le 30/10/2019 à 19:29, Jorge Gustavo Rocha a écrit :
> Hi Ken,
> Where are you storing the new layer? Maybe you are not selecting a folder
> where you can write the new shapefile (that's why you get the permission
> denied error). Can you confirm the location of the new shapefile?
> Regards,
> Jorge Gustavo
> Às 16:15 de 30/10/19, Ken McCall escreveu:
> After years of using ARCGIS, I’m using the training manual to become
> acquainted with QGIS. I’ve downloaded 3.8, and worked through the first 100
> pages with no problem. While  some of the 3.8 dialog boxes don’t look
> like the training manual I’ve been able to see the required buttons, drop
> downs, etc. But on others, I’ve hit some deadends.
> For example, on page 105 when it try to create a dynamic map canvas, in
> 5.2.1.5, when I go to the Item *Properties Panel*, there is no *Position
> and Size* section showing.
> Another example: On p. 114 in ‘Creating a New Vector Dataset’, when I try
> to save the dataset, I get an error message:
> ‘Layer creation failed: Failed to create file created_shapefile.shp:
> Permission denied.
> In both examples, I’ve tried several times, following the instructions,
> only to get the same result.
> So, questions:
> Is 3.8 that different from 3.4?
> Am I running into bugs in the software or the documentation? (It could be
> user error, but I’m painstakingly following the instructions.)
> Should I scrap 3.8 and go with 3.4 instead?
> TIA,
> Ken McCall
> Qgis-user mailing listQgis-user at lists.osgeo.org
> [image: Logo] <https://www.geomaster.pt>
> *Geomaster*
> *Jorge Gustavo Rocha* | Software Engineer
> *e:* jgr at geomaster.pt | *m:* +351 910 333 888
> *g:* 41.54094,-8.40490 | *v: * 510 906 109
> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191030/5c20b973/attachment.html>
