[Qgis-user] Problems using QGIS 3.8 with the 3.4 Training Manual
SIGéal sigeal at sigeal.com
Wed Oct 30 12:13:19 PDT 2019
I remember having this problem if I typed the shapefile name directly in
the textbox, without clicking on the Browse button to select a location
for the file.
Hope this helps,
Christophe
Le 30/10/2019 à 19:29, Jorge Gustavo Rocha a écrit :
> Hi Ken,
> Where are you storing the new layer? Maybe you are not selecting a
> folder where you can write the new shapefile (that's why you get the
> permission denied error). Can you confirm the location of the new
> shapefile?
> Regards,
> Jorge Gustavo
> Às 16:15 de 30/10/19, Ken McCall escreveu:
>> After years of using ARCGIS, I’m using the training manual to become
>> acquainted with QGIS. I’ve downloaded 3.8, and worked through the
>> first 100 pages with no problem. While some of the 3.8 dialog boxes
>> don’t look like the training manual I’ve been able to see the
>> required buttons, drop downs, etc. But on others, I’ve hit some deadends.
>> For example, on page 105 when it try to create a dynamic map canvas,
>> in 5.2.1.5, when I go to the Item /Properties Panel/, there is no
>> /Position and Size/ section showing.
>> Another example: On p. 114 in ‘Creating a New Vector Dataset’, when I
>> try to save the dataset, I get an error message:
>> ‘Layer creation failed: Failed to create file created_shapefile.shp:
>> Permission denied.
>> In both examples, I’ve tried several times, following the
>> instructions, only to get the same result.
>> So, questions:
>> Is 3.8 that different from 3.4?
>> Am I running into bugs in the software or the documentation? (It
>> could be user error, but I’m painstakingly following the instructions.)
>> Should I scrap 3.8 and go with 3.4 instead?
>> TIA,
>> Ken McCall
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Email Signature
> Logo <https://www.geomaster.pt>
> *Geomaster*
> *Jorge Gustavo Rocha* | Software Engineer
> *e:*jgr at geomaster.pt | *m:*+351 910 333 888
> *g:*41.54094,-8.40490 | *v: *510 906 109
> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191030/44da8ff8/attachment.html>
