[Qgis-user] Qgis-user Digest, Vol 164, Issue 47
Ken McCall kenrmccall at gmail.com
Thu Oct 31 09:08:32 PDT 2019
Yep! It was where I was storing the file. The Training Manual instructions
are outdated here at the bottom of p. 114.
Thanks to Jorge and Christophe!
On Wed, Oct 30, 2019 at 3:03 PM <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
>         qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>    1. Re: Crash when opening project with QGIS 3.10 (Alessandro Pasotti)
>    2. Re: Crash when opening project with QGIS 3.10 (Even Rouault)
>    3. Re: Crash when opening project with QGIS 3.10 (Alessandro Pasotti)
>    4. Problems using QGIS 3.8 with the 3.4 Training Manual (Ken McCall)
>    5. Re: Problems using QGIS 3.8 with the 3.4 Training Manual
>       (Jorge Gustavo Rocha)
> Message: 1
> Date: Wed, 30 Oct 2019 15:24:47 +0100
> From: Alessandro Pasotti <apasotti at gmail.com>
> To: ben hutcher <benhutcher123 at gmail.com>
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Crash when opening project with QGIS 3.10
> Message-ID:
> CAL5Q670hAeXt6j_cketGowhQdcEnwiqxixM7MU9MMZEi+3rJ_g at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> On Wed, Oct 30, 2019 at 2:54 PM ben hutcher <benhutcher123 at gmail.com>
> wrote:
> > Hi,
> > I've just tried the new release, and I have a crash when trying to reopen
> > a project that I've just saved. Can other people replicate that with the
> > attached project and advise how to fix that  ?
> I actually unzipped and inspected the project before loading it (because I
> know enough about QGIS internals to know what to trust).
> What's this about? A social experiment?
> om qgis.PyQt.QtWidgets import QMessageBox
>     QMessageBox.critical(None, "Nearly busted !",
>         "Do you realize you blindly accepted to run untrusted code " + \
>         "that could have destroyed your computer, stolen your passwords,
> etc. ?\n" + \
>         "Be reassured, nothing at all apart emitting this message has been
> done.\n" + \
>         "This was just an experiment to check how users react to the
> default security warning. " + \
>         "If you've read that message, please add a new line to
> http://collabedit.com/662b2")
> Thanks,
> > Ben
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> w3:   www.itopen.it
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20191030/11d2404b/attachment-0001.html
> Message: 2
> Date: Wed, 30 Oct 2019 15:47:07 +0100
> From: Even Rouault <even.rouault at spatialys.com>
> To: qgis-user at lists.osgeo.org
> Message-ID: <2931006.8PTlG7Zoom at even-i700>
> Content-Type: text/plain; charset="us-ascii"
> Yes, I'm "Ben Hutcher". Too bad you destroyed it so quickly :-)
> I just discovered this functionnality of QGIS and this scared me. I
> believe I
> would have accepted the warning because I ignored that QGIS projects could
> contain Python code, and I presume a lot of users would. IMHO clicking on
> the
> Enable macros link should raise a dialog box with a more explicit message
> about the potential risks to double confirm.
> "Python macros cannot currently be run." sounds to me as "you should
> enable
> macros so things work as expected". It is not even clear that the macros
> come
> from the project itself. They could be some trusted code in QGIS itself.
> Once
> you know that functionnality is, then yes the current behaviour is
> probably
> fine. But if you don't know it, there's a high chance you could run
> untrusted
> code without realizing it.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> Message: 3
> Date: Wed, 30 Oct 2019 15:56:35 +0100
> To: Even Rouault <even.rouault at spatialys.com>
> Message-ID:
>         <CAL5Q672rEXWeL5fDFdO8Jy1v=
> 0zN6WkuRRRkKB7dDoS2vO8vsQ at mail.gmail.com>
> On Wed, Oct 30, 2019 at 3:47 PM Even Rouault <even.rouault at spatialys.com>
> Oh, I'm sorry :)
> You should have told me ... you know, I'm in bug-fixing-mode and I couldn't
> resist ;)
> > believe I
> could
> > the
> > enable
> > come
> > Once
> > probably
> > untrusted
> > Even
> Agreed (same for Python code embedded in forms btw).
> We should warn users about the security threats associates to run untrusted
> code (now forms have also the option to download code from the network and
> run it!).
> Plugins as well are of course a potential threat.
> Alessandro Pasotti
> w3:   www.itopen.it
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20191030/a468e6c9/attachment-0001.html
> Message: 4
> Date: Wed, 30 Oct 2019 12:15:27 -0400
> From: Ken McCall <kenrmccall at gmail.com>
> Subject: [Qgis-user] Problems using QGIS 3.8 with the 3.4 Training
>         Manual
> Message-ID:
> CAFobhFJePfAbSUjYtdBEkGOogP2yXc4Djkja2Q7+FkKWtU5YQg at mail.gmail.com>
> After years of using ARCGIS, I’m using the training manual to become
> acquainted with QGIS. I’ve downloaded 3.8, and worked through the first 100
> pages with no problem. While  some of the 3.8 dialog boxes don’t look like
> the training manual I’ve been able to see the required buttons, drop downs,
> etc. But on others, I’ve hit some deadends.
> For example, on page 105 when it try to create a dynamic map canvas, in
> 5.2.1.5, when I go to the Item *Properties Panel*, there is no *Position
> and Size* section showing.
> Another example: On p. 114 in ‘Creating a New Vector Dataset’, when I try
> to save the dataset, I get an error message:
> ‘Layer creation failed: Failed to create file created_shapefile.shp:
> Permission denied.
> In both examples, I’ve tried several times, following the instructions,
> only to get the same result.
> So, questions:
> Is 3.8 that different from 3.4?
> Am I running into bugs in the software or the documentation? (It could be
> user error, but I’m painstakingly following the instructions.)
> Should I scrap 3.8 and go with 3.4 instead?
> TIA,
> Ken McCall
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20191030/e0a90632/attachment-0001.html
> Message: 5
> Date: Wed, 30 Oct 2019 18:29:19 +0000
> From: Jorge Gustavo Rocha <jgr at geomaster.pt>
> Subject: Re: [Qgis-user] Problems using QGIS 3.8 with the 3.4 Training
>         Manual
> Message-ID: <41f45dde-7906-7776-67e7-1bfb0a81dd28 at geomaster.pt>
> Hi Ken,
> Where are you storing the new layer? Maybe you are not selecting a
> folder where you can write the new shapefile (that's why you get the
> permission denied error). Can you confirm the location of the new
> shapefile?
> Regards,
> Jorge Gustavo
> Às 16:15 de 30/10/19, Ken McCall escreveu:
> > first 100 pages with no problem. While  some of the 3.8 dialog boxes
> > don’t look like the training manual I’ve been able to see the required
> > buttons, drop downs, etc. But on others, I’ve hit some deadends.
> > in 5.2.1.5, when I go to the Item /Properties Panel/, there is no
> > /Position and Size/ section showing.
> > try to save the dataset, I get an error message:
> > Permission denied.
> > instructions, only to get the same result.
> > So, questions:
> > be user error, but I’m painstakingly following the instructions.)
> > TIA,
> > Ken McCall
> Email Signature
> Logo <https://www.geomaster.pt>
> *Geomaster*
> *Jorge Gustavo Rocha* | Software Engineer
> *e:*jgr at geomaster.pt | *m:*+351 910 333 888
> *g:*41.54094,-8.40490 | *v: *510 906 109
> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20191030/896098dc/attachment-0001.html
> Subject: Digest Footer
> End of Qgis-user Digest, Vol 164, Issue 47
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191031/a0987cce/attachment.html>
