[Qgis-user] Importing a raster into a Geopackage
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Tue Dec 1 08:39:38 PST 2020
Send a sample data set if you can't figure it out.
Nicolas
On 2020-12-01 10:35 a.m., Nicolas Cadieux wrote:
> Hi,
> Perhaps this can help: https://gdal.orgdrivers/raster/gpkg.html
> <https://gdal.orgdrivers/raster/gpkg.html>
> “Various kind of input datasets can be converted to GeoPackage raster :
> Single band grey level
> Single band with R,G,B or R,G,B,A color table
> Two bands: first band with grey level, second band with alpha channel
> Three bands: Red, Green, Blue
> Four band: Red, Green, Blue, Alpha
> GeoPackage rasters only support Byte data type.”
> My guess is that if the original raster does not correspond to one of
> the categories above, it will be converted to the closest format.
> Nicolas Cadieux
> https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
>> Le 1 déc. 2020 à 09:58, Alberto Vavassori
>> <alberto.vavassori at polimi.it> a écrit :
>> Hello everybody. I have an issue regarding the Geopackage format. I
>> have tried to import a singleband raster file (it represents the land
>> cover, thus every pixel has a single integer value corresponding to
>> the land cover class), but this operation seems to modify the raster
>> characteristics: the raster becomes a 4-bands raster and the pixels
>> values change accordingly (basically, the original raster is saved in
>> the Geopackage as an RGB image). It seems to be a bug of QGIS. I have
>> also tried to use GDAL translate through the processing toolbox of
>> QGIS to convert the TIFF file to a Geopackage file, but the result is
>> the same.
>> Has anybody faced this problem? May anybody suggest a way to work
>> this problem out?
>> Thank you.
>> Alberto
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201201/47ebb2fd/attachment.html>
