[Qgis-user] R: Importing a raster into a Geopackage
Kirk Schmidt kirk at nortekresources.com
Tue Dec 1 10:28:39 PST 2020
Hi Nicolas:
try the -b 1 parameter.  I just tried this and wrote a single band
raster from a 3 channel tiff.
Kirk
On 12/1/2020 2:03 PM, Nicolas Cadieux wrote:
> I tried
> gdal_translate -of GPKG -co "BAND_COUNT=1"
> C:/Users/Nicolas/Desktop/Land_cover_Corine2018.tif
> C:/Users/Nicolas/Desktop/TEST.gpkg for the creation and
> C:\>gdal_translate -of GPKG -co "TILE_FORMAT = TIFF"
> Same problem.  I wonder if we need to change the reading options...
> https://gdal.org/drivers/raster/gpkg.html
>     "Opening options
> By default, the driver will expose a GeoPackage dataset as a four band
> (Red,Green, Blue,Alpha) dataset, which gives the maximum compatibility
> with the various encodings of tiles that can be stored. It is possible
> to specify an explicit number of bands with the BAND_COUNT opening
> option."
> The problem could be when QGIS Reads the file, not when it writes the
> file.  I explains why we see 4 bands but not why values are changing.
> I would make a bug report or ask the question on the gdal dev group to
> get Even Rouault's attention.
> Nicolas
> On 2020-12-01 12:17 p.m., Sebastian Gutwein wrote:
>> This looks like the same issue you are having.
>> github.com/qgis/QGIS/issues/38227
>> <http://github.com/qgis/QGIS/issues/38227>
>> According to the documentation linked in the issue you need to set
>> the band count to 1 otherwise it defaults to 4.
>> <http://gdal.org/drivers/raster/gpkg.html>
>> I have not tried this to see if it works.
>> On Tue, Dec 1, 2020 at 11:52 AM Nicolas Cadieux
>> <njacadieux.gitlab at gmail.com <mailto:njacadieux.gitlab at gmail.com>> wrote:
>>     Hi,
>>     Looking at it now.  I see what you see.  I will try a few things.
>>     Nicolas
>>     On 2020-12-01 11:42 a.m., Alberto Vavassori wrote:
>>>     Hi Nicolas,
>>>     thank you for the answer. I send the raster that I am interested in.
>>>     Alberto
>>>     *Da:*Nicolas Cadieux <njacadieux.gitlab at gmail.com>
>>>     *Inviato:* martedì 1 dicembre 2020 17:40
>>>     *A:* Alberto Vavassori <alberto.vavassori at polimi.it>
>>>     <mailto:alberto.vavassori at polimi.it>
>>>     *Cc:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
>>>     *Oggetto:* Re: [Qgis-user] Importing a raster into a Geopackage
>>>     Hi,
>>>     Send a sample data set if you can't figure it out.
>>>     Nicolas
>>>     On 2020-12-01 10:35 a.m., Nicolas Cadieux wrote:
>>>         Hi,
>>>         Perhaps this can help:
>>>         https://gdal.orgdrivers/raster/gpkg.html
>>>         <https://gdal.orgdrivers/raster/gpkg.html>
>>>         “Various kind of input datasets can be converted to
>>>         GeoPackage raster :
>>>         ·Single band grey level
>>>         ·Single band with R,G,B or R,G,B,A color table
>>>         ·Two bands: first band with grey level, second band with
>>>         alpha channel
>>>         ·Three bands: Red, Green, Blue
>>>         ·Four band: Red, Green, Blue, Alpha
>>>         GeoPackage rasters only support Byte data type.”
>>>         My guess is that if the original raster does not correspond
>>>         to one of the categories above, it will be converted to the
>>>         closest format.
>>>         Nicolas Cadieux
>>>         https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
>>>             Le 1 déc. 2020 à 09:58, Alberto Vavassori
>>>             <mailto:alberto.vavassori at polimi.it> a écrit :
>>>             Hello everybody. I have an issue regarding the
>>>             Geopackage format. I have tried to import a singleband
>>>             raster file (it represents the land cover, thus every
>>>             pixel has a single integer value corresponding to the
>>>             land cover class), but this operation seems to modify
>>>             the raster characteristics: the raster becomes a 4-bands
>>>             raster and the pixels values change accordingly
>>>             (basically, the original raster is saved in the
>>>             Geopackage as an RGB image). It seems to be a bug of
>>>             QGIS. I have also tried to use GDAL translate through
>>>             the processing toolbox of QGIS to convert the TIFF file
>>>             to a Geopackage file, but the result is the same.
>>>             Has anybody faced this problem? May anybody suggest a
>>>             way to work this problem out?
>>>             Thank you.
>>>             Alberto
>>>             _______________________________________________
>>>             Qgis-user mailing list
>>>             Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>             List info:
>>>             https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>             <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>             Unsubscribe:
>>>     Nicolas Cadieux
>>     Nicolas Cadieux
>>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Nicolas Cadieux
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com
Web: www.nortekresources.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201201/568cf30b/attachment-0001.html>
