[Qgis-user] R: Importing a raster into a Geopackage
Nicolas Cadieux njacadieux.gitlab at gmail.com
Tue Dec 1 10:36:33 PST 2020
Tried this:
gdal_translate -of GPKG -b 1
C:/Users/Nicolas/Desktop/Land_cover_Corine2018.tif
C:/Users/Nicolas/Desktop/test.gpkg
I read 4 band and still get data modifications.
Nicolas
On 2020-12-01 1:28 p.m., Kirk Schmidt wrote:
> Hi Nicolas:
> try the -b 1 parameter.  I just tried this and wrote a single band
> raster from a 3 channel tiff.
> Kirk
> On 12/1/2020 2:03 PM, Nicolas Cadieux wrote:
>> I tried
>> gdal_translate -of GPKG -co "BAND_COUNT=1"
>> C:/Users/Nicolas/Desktop/TEST.gpkg for the creation and
>> C:\>gdal_translate -of GPKG -co "TILE_FORMAT = TIFF"
>> Same problem.  I wonder if we need to change the reading options...
>> https://gdal.org/drivers/raster/gpkg.html
>>     "Opening options
>> By default, the driver will expose a GeoPackage dataset as a four
>> band (Red,Green, Blue,Alpha) dataset, which gives the maximum
>> compatibility with the various encodings of tiles that can be stored.
>> It is possible to specify an explicit number of bands with the
>> BAND_COUNT opening option."
>> The problem could be when QGIS Reads the file, not when it writes the
>> file.  I explains why we see 4 bands but not why values are
>> changing.  I would make a bug report or ask the question on the gdal
>> dev group to get Even Rouault's attention.
>> Nicolas
>> On 2020-12-01 12:17 p.m., Sebastian Gutwein wrote:
>>> This looks like the same issue you are having.
>>> github.com/qgis/QGIS/issues/38227
>>> <http://github.com/qgis/QGIS/issues/38227>
>>> According to the documentation linked in the issue you need to set
>>> the band count to 1 otherwise it defaults to 4.
>>> <http://gdal.org/drivers/raster/gpkg.html>
>>> I have not tried this to see if it works.
>>> On Tue, Dec 1, 2020 at 11:52 AM Nicolas Cadieux
>>> <njacadieux.gitlab at gmail.com <mailto:njacadieux.gitlab at gmail.com>>
>>> wrote:
>>>     Hi,
>>>     Looking at it now.  I see what you see.  I will try a few things.
>>>     Nicolas
>>>     On 2020-12-01 11:42 a.m., Alberto Vavassori wrote:
>>>>     Hi Nicolas,
>>>>     thank you for the answer. I send the raster that I am
>>>>     interested in.
>>>>     Alberto
>>>>     *Da:*Nicolas Cadieux <njacadieux.gitlab at gmail.com>
>>>>     *Inviato:* martedì 1 dicembre 2020 17:40
>>>>     *A:* Alberto Vavassori <alberto.vavassori at polimi.it>
>>>>     <mailto:alberto.vavassori at polimi.it>
>>>>     *Cc:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
>>>>     *Oggetto:* Re: [Qgis-user] Importing a raster into a Geopackage
>>>>     Hi,
>>>>     Send a sample data set if you can't figure it out.
>>>>     Nicolas
>>>>     On 2020-12-01 10:35 a.m., Nicolas Cadieux wrote:
>>>>         Hi,
>>>>         Perhaps this can help:
>>>>         https://gdal.orgdrivers/raster/gpkg.html
>>>>         <https://gdal.orgdrivers/raster/gpkg.html>
>>>>         “Various kind of input datasets can be converted to
>>>>         GeoPackage raster :
>>>>         ·Single band grey level
>>>>         ·Single band with R,G,B or R,G,B,A color table
>>>>         ·Two bands: first band with grey level, second band with
>>>>         alpha channel
>>>>         ·Three bands: Red, Green, Blue
>>>>         ·Four band: Red, Green, Blue, Alpha
>>>>         GeoPackage rasters only support Byte data type.”
>>>>         My guess is that if the original raster does not correspond
>>>>         to one of the categories above, it will be converted to the
>>>>         closest format.
>>>>         Nicolas Cadieux
>>>>         https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
>>>>             Le 1 déc. 2020 à 09:58, Alberto Vavassori
>>>>             <mailto:alberto.vavassori at polimi.it> a écrit :
>>>>             Hello everybody. I have an issue regarding the
>>>>             Geopackage format. I have tried to import a singleband
>>>>             raster file (it represents the land cover, thus every
>>>>             pixel has a single integer value corresponding to the
>>>>             land cover class), but this operation seems to modify
>>>>             the raster characteristics: the raster becomes a
>>>>             4-bands raster and the pixels values change accordingly
>>>>             (basically, the original raster is saved in the
>>>>             Geopackage as an RGB image). It seems to be a bug of
>>>>             QGIS. I have also tried to use GDAL translate through
>>>>             the processing toolbox of QGIS to convert the TIFF file
>>>>             to a Geopackage file, but the result is the same.
>>>>             Has anybody faced this problem? May anybody suggest a
>>>>             way to work this problem out?
>>>>             Thank you.
>>>>             Alberto
>>>>             _______________________________________________
>>>>             Qgis-user mailing list
>>>>             Qgis-user at lists.osgeo.org
>>>>             <mailto:Qgis-user at lists.osgeo.org>
>>>>             List info:
>>>>             https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>             <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>             Unsubscribe:
>>>>     Nicolas Cadieux
>>>     Nicolas Cadieux
>>>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Nicolas Cadieux
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Kirk Schmidt, MScF, BScF, RPF
> General Manager
> Nortek Resource Solutions Inc.
> RR # 1
> Thorburn, NS
> B0K 1W0
> Tel (902) 922.3607
> Email:kirk at nortekresources.com
> Web:www.nortekresources.com
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201201/130ded58/attachment.html>
