[Qgis-user] R: Importing a raster into a Geopackage
Kirk Schmidt kirk at nortekresources.com
Tue Dec 1 10:58:12 PST 2020
Hi Nicolas
I did the same and the legend indicates a change magnitude but if I
subtract the geopackage raster from the original, all pixels equal zero.
Kirk
On 12/1/2020 2:36 PM, Nicolas Cadieux wrote:
> Hi,
> Tried this:
> gdal_translate -of GPKG -b 1
> C:/Users/Nicolas/Desktop/Land_cover_Corine2018.tif
> C:/Users/Nicolas/Desktop/test.gpkg
> I read 4 band and still get data modifications.
> Nicolas
> On 2020-12-01 1:28 p.m., Kirk Schmidt wrote:
>> Hi Nicolas:
>> try the -b 1 parameter.  I just tried this and wrote a single band
>> raster from a 3 channel tiff.
>> Kirk
>> On 12/1/2020 2:03 PM, Nicolas Cadieux wrote:
>>> I tried
>>> gdal_translate -of GPKG -co "BAND_COUNT=1"
>>> C:/Users/Nicolas/Desktop/TEST.gpkg for the creation and
>>> C:\>gdal_translate -of GPKG -co "TILE_FORMAT = TIFF"
>>> Same problem.  I wonder if we need to change the reading options...
>>> https://gdal.org/drivers/raster/gpkg.html
>>>     "Opening options
>>> By default, the driver will expose a GeoPackage dataset as a four
>>> band (Red,Green, Blue,Alpha) dataset, which gives the maximum
>>> compatibility with the various encodings of tiles that can be
>>> stored. It is possible to specify an explicit number of bands with
>>> the BAND_COUNT opening option."
>>> The problem could be when QGIS Reads the file, not when it writes
>>> the file.  I explains why we see 4 bands but not why values are
>>> changing.  I would make a bug report or ask the question on the gdal
>>> dev group to get Even Rouault's attention.
>>> Nicolas
>>> On 2020-12-01 12:17 p.m., Sebastian Gutwein wrote:
>>>> This looks like the same issue you are having.
>>>> github.com/qgis/QGIS/issues/38227
>>>> <http://github.com/qgis/QGIS/issues/38227>
>>>> According to the documentation linked in the issue you need to set
>>>> the band count to 1 otherwise it defaults to 4.
>>>> <http://gdal.org/drivers/raster/gpkg.html>
>>>> I have not tried this to see if it works.
>>>> On Tue, Dec 1, 2020 at 11:52 AM Nicolas Cadieux
>>>> <njacadieux.gitlab at gmail.com <mailto:njacadieux.gitlab at gmail.com>>
>>>> wrote:
>>>>     Hi,
>>>>     Looking at it now.  I see what you see.  I will try a few things.
>>>>     Nicolas
>>>>     On 2020-12-01 11:42 a.m., Alberto Vavassori wrote:
>>>>>     Hi Nicolas,
>>>>>     thank you for the answer. I send the raster that I am
>>>>>     interested in.
>>>>>     Alberto
>>>>>     *Da:*Nicolas Cadieux <njacadieux.gitlab at gmail.com>
>>>>>     *Inviato:* martedì 1 dicembre 2020 17:40
>>>>>     *A:* Alberto Vavassori <alberto.vavassori at polimi.it>
>>>>>     <mailto:alberto.vavassori at polimi.it>
>>>>>     *Cc:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
>>>>>     *Oggetto:* Re: [Qgis-user] Importing a raster into a Geopackage
>>>>>     Hi,
>>>>>     Send a sample data set if you can't figure it out.
>>>>>     Nicolas
>>>>>     On 2020-12-01 10:35 a.m., Nicolas Cadieux wrote:
>>>>>         Hi,
>>>>>         Perhaps this can help:
>>>>>         https://gdal.orgdrivers/raster/gpkg.html
>>>>>         <https://gdal.orgdrivers/raster/gpkg.html>
>>>>>         “Various kind of input datasets can be converted to
>>>>>         GeoPackage raster :
>>>>>         ·Single band grey level
>>>>>         ·Single band with R,G,B or R,G,B,A color table
>>>>>         ·Two bands: first band with grey level, second band with
>>>>>         alpha channel
>>>>>         ·Three bands: Red, Green, Blue
>>>>>         ·Four band: Red, Green, Blue, Alpha
>>>>>         GeoPackage rasters only support Byte data type.”
>>>>>         My guess is that if the original raster does not
>>>>>         correspond to one of the categories above, it will be
>>>>>         converted to the closest format.
>>>>>         Nicolas Cadieux
>>>>>         https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
>>>>>             Le 1 déc. 2020 à 09:58, Alberto Vavassori
>>>>>             <mailto:alberto.vavassori at polimi.it> a écrit :
>>>>>             Hello everybody. I have an issue regarding the
>>>>>             Geopackage format. I have tried to import a singleband
>>>>>             raster file (it represents the land cover, thus every
>>>>>             pixel has a single integer value corresponding to the
>>>>>             land cover class), but this operation seems to modify
>>>>>             the raster characteristics: the raster becomes a
>>>>>             4-bands raster and the pixels values change
>>>>>             accordingly (basically, the original raster is saved
>>>>>             in the Geopackage as an RGB image). It seems to be a
>>>>>             bug of QGIS. I have also tried to use GDAL translate
>>>>>             through the processing toolbox of QGIS to convert the
>>>>>             TIFF file to a Geopackage file, but the result is the
>>>>>             same.
>>>>>             Has anybody faced this problem? May anybody suggest a
>>>>>             way to work this problem out?
>>>>>             Thank you.
>>>>>             Alberto
>>>>>             _______________________________________________
>>>>>             Qgis-user mailing list
>>>>>             Qgis-user at lists.osgeo.org
>>>>>             <mailto:Qgis-user at lists.osgeo.org>
>>>>>             List info:
>>>>>             https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>             <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>>             Unsubscribe:
>>>>>     Nicolas Cadieux
>>>>     Nicolas Cadieux
>>>>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Nicolas Cadieux
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Kirk Schmidt, MScF, BScF, RPF
>> General Manager
>> Nortek Resource Solutions Inc.
>> RR # 1
>> Thorburn, NS
>> B0K 1W0
>> Tel (902) 922.3607
>> Email:kirk at nortekresources.com
>> Web:www.nortekresources.com
> Nicolas Cadieux
General Manager
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com
Web: www.nortekresources.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201201/eca05d05/attachment-0001.html>
