[Qgis-user] R: Importing a raster into a Geopackage
Nicolas Cadieux njacadieux.gitlab at gmail.com
Tue Dec 1 11:03:07 PST 2020
Same here, very different results
https://drive.google.com/file/d/1GyIhYMWSdZFtI4uHQOLOyJpmcqDLrx4K/view?usp=sharing
I'am on 3.16.1, Window 10
Nicolas
On 2020-12-01 1:58 p.m., Kirk Schmidt wrote:
> Hi Nicolas
> I did the same and the legend indicates a change magnitude but if I
> subtract the geopackage raster from the original, all pixels equal zero.
> Kirk
> On 12/1/2020 2:36 PM, Nicolas Cadieux wrote:
>> Hi,
>> Tried this:
>> gdal_translate -of GPKG -b 1
>> C:/Users/Nicolas/Desktop/Land_cover_Corine2018.tif
>> C:/Users/Nicolas/Desktop/test.gpkg
>> I read 4 band and still get data modifications.
>> Nicolas
>> On 2020-12-01 1:28 p.m., Kirk Schmidt wrote:
>>> Hi Nicolas:
>>> try the -b 1 parameter.  I just tried this and wrote a single band
>>> raster from a 3 channel tiff.
>>> Kirk
>>> On 12/1/2020 2:03 PM, Nicolas Cadieux wrote:
>>>> I tried
>>>> gdal_translate -of GPKG -co "BAND_COUNT=1"
>>>> C:/Users/Nicolas/Desktop/TEST.gpkg for the creation and
>>>> C:\>gdal_translate -of GPKG -co "TILE_FORMAT = TIFF"
>>>> Same problem.  I wonder if we need to change the reading options...
>>>> https://gdal.org/drivers/raster/gpkg.html
>>>>     "Opening options
>>>> By default, the driver will expose a GeoPackage dataset as a four
>>>> band (Red,Green, Blue,Alpha) dataset, which gives the maximum
>>>> compatibility with the various encodings of tiles that can be
>>>> stored. It is possible to specify an explicit number of bands with
>>>> the BAND_COUNT opening option."
>>>> The problem could be when QGIS Reads the file, not when it writes
>>>> the file.  I explains why we see 4 bands but not why values are
>>>> changing.  I would make a bug report or ask the question on the
>>>> gdal dev group to get Even Rouault's attention.
>>>> Nicolas
>>>> On 2020-12-01 12:17 p.m., Sebastian Gutwein wrote:
>>>>> This looks like the same issue you are having.
>>>>> github.com/qgis/QGIS/issues/38227
>>>>> <http://github.com/qgis/QGIS/issues/38227>
>>>>> According to the documentation linked in the issue you need to set
>>>>> the band count to 1 otherwise it defaults to 4.
>>>>> <http://gdal.org/drivers/raster/gpkg.html>
>>>>> I have not tried this to see if it works.
>>>>> On Tue, Dec 1, 2020 at 11:52 AM Nicolas Cadieux
>>>>> <njacadieux.gitlab at gmail.com <mailto:njacadieux.gitlab at gmail.com>>
>>>>> wrote:
>>>>>     Hi,
>>>>>     Looking at it now.  I see what you see.  I will try a few things.
>>>>>     Nicolas
>>>>>     On 2020-12-01 11:42 a.m., Alberto Vavassori wrote:
>>>>>>     Hi Nicolas,
>>>>>>     thank you for the answer. I send the raster that I am
>>>>>>     interested in.
>>>>>>     Alberto
>>>>>>     *Da:*Nicolas Cadieux <njacadieux.gitlab at gmail.com>
>>>>>>     *Inviato:* martedì 1 dicembre 2020 17:40
>>>>>>     *A:* Alberto Vavassori <alberto.vavassori at polimi.it>
>>>>>>     <mailto:alberto.vavassori at polimi.it>
>>>>>>     *Cc:* qgis-user at lists.osgeo.org
>>>>>>     <mailto:qgis-user at lists.osgeo.org>
>>>>>>     *Oggetto:* Re: [Qgis-user] Importing a raster into a Geopackage
>>>>>>     Hi,
>>>>>>     Send a sample data set if you can't figure it out.
>>>>>>     Nicolas
>>>>>>     On 2020-12-01 10:35 a.m., Nicolas Cadieux wrote:
>>>>>>         Hi,
>>>>>>         Perhaps this can help:
>>>>>>         https://gdal.orgdrivers/raster/gpkg.html
>>>>>>         <https://gdal.orgdrivers/raster/gpkg.html>
>>>>>>         “Various kind of input datasets can be converted to
>>>>>>         GeoPackage raster :
>>>>>>         ·Single band grey level
>>>>>>         ·Single band with R,G,B or R,G,B,A color table
>>>>>>         ·Two bands: first band with grey level, second band with
>>>>>>         alpha channel
>>>>>>         ·Three bands: Red, Green, Blue
>>>>>>         ·Four band: Red, Green, Blue, Alpha
>>>>>>         GeoPackage rasters only support Byte data type.”
>>>>>>         My guess is that if the original raster does not
>>>>>>         correspond to one of the categories above, it will be
>>>>>>         converted to the closest format.
>>>>>>         Nicolas Cadieux
>>>>>>         https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
>>>>>>             Le 1 déc. 2020 à 09:58, Alberto Vavassori
>>>>>>             <mailto:alberto.vavassori at polimi.it> a écrit :
>>>>>>             Hello everybody. I have an issue regarding the
>>>>>>             Geopackage format. I have tried to import a
>>>>>>             singleband raster file (it represents the land cover,
>>>>>>             thus every pixel has a single integer value
>>>>>>             corresponding to the land cover class), but this
>>>>>>             operation seems to modify the raster characteristics:
>>>>>>             the raster becomes a 4-bands raster and the pixels
>>>>>>             values change accordingly (basically, the original
>>>>>>             raster is saved in the Geopackage as an RGB image).
>>>>>>             It seems to be a bug of QGIS. I have also tried to
>>>>>>             use GDAL translate through the processing toolbox of
>>>>>>             QGIS to convert the TIFF file to a Geopackage file,
>>>>>>             but the result is the same.
>>>>>>             Has anybody faced this problem? May anybody suggest a
>>>>>>             way to work this problem out?
>>>>>>             Thank you.
>>>>>>             Alberto
>>>>>>             _______________________________________________
>>>>>>             Qgis-user mailing list
>>>>>>             Qgis-user at lists.osgeo.org
>>>>>>             <mailto:Qgis-user at lists.osgeo.org>
>>>>>>             List info:
>>>>>>             https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>             <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>>>             Unsubscribe:
>>>>>>     Nicolas Cadieux
>>>>>     Nicolas Cadieux
>>>>>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>>>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>     Unsubscribe:
>>>> Nicolas Cadieux
>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Kirk Schmidt, MScF, BScF, RPF
>>> General Manager
>>> Nortek Resource Solutions Inc.
>>> RR # 1
>>> Thorburn, NS
>>> B0K 1W0
>>> Tel (902) 922.3607
>>> Email:kirk at nortekresources.com
>>> Web:www.nortekresources.com
>> Nicolas Cadieux
> General Manager
> RR # 1
> Thorburn, NS
> B0K 1W0
> Tel (902) 922.3607
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201201/d0881a17/attachment.html>
