[Qgis-user] R: Importing a raster into a Geopackage
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Tue Dec 1 11:24:19 PST 2020
I changed the link so you have access to more files.
https://drive.google.com/drive/folders/1fMl9odowUFFRQFK61rTxgHeom_D8ymN6?usp=sharing
Nicolas
On 2020-12-01 1:58 p.m., Kirk Schmidt wrote:
> Hi Nicolas
> I did the same and the legend indicates a change magnitude but if I
> subtract the geopackage raster from the original, all pixels equal zero.
> Kirk
> On 12/1/2020 2:36 PM, Nicolas Cadieux wrote:
>> Hi,
>> Tried this:
>> gdal_translate -of GPKG -b 1
>> C:/Users/Nicolas/Desktop/Land_cover_Corine2018.tif
>> C:/Users/Nicolas/Desktop/test.gpkg
>> I read 4 band and still get data modifications.
>> Nicolas
>> On 2020-12-01 1:28 p.m., Kirk Schmidt wrote:
>>> Hi Nicolas:
>>> try the -b 1 parameter. I just tried this and wrote a single band
>>> raster from a 3 channel tiff.
>>> Kirk
>>> On 12/1/2020 2:03 PM, Nicolas Cadieux wrote:
>>>> I tried
>>>> gdal_translate -of GPKG -co "BAND_COUNT=1"
>>>> C:/Users/Nicolas/Desktop/TEST.gpkg for the creation and
>>>> C:\>gdal_translate -of GPKG -co "TILE_FORMAT = TIFF"
>>>> Same problem. I wonder if we need to change the reading options...
>>>> https://gdal.org/drivers/raster/gpkg.html
>>>> "Opening options
>>>> By default, the driver will expose a GeoPackage dataset as a four
>>>> band (Red,Green, Blue,Alpha) dataset, which gives the maximum
>>>> compatibility with the various encodings of tiles that can be
>>>> stored. It is possible to specify an explicit number of bands with
>>>> the BAND_COUNT opening option."
>>>> The problem could be when QGIS Reads the file, not when it writes
>>>> the file. I explains why we see 4 bands but not why values are
>>>> changing. I would make a bug report or ask the question on the
>>>> gdal dev group to get Even Rouault's attention.
>>>> Nicolas
>>>> On 2020-12-01 12:17 p.m., Sebastian Gutwein wrote:
>>>>> This looks like the same issue you are having.
>>>>> github.com/qgis/QGIS/issues/38227
>>>>> <http://github.com/qgis/QGIS/issues/38227>
>>>>> According to the documentation linked in the issue you need to set
>>>>> the band count to 1 otherwise it defaults to 4.
>>>>> <http://gdal.org/drivers/raster/gpkg.html>
>>>>> I have not tried this to see if it works.
>>>>> On Tue, Dec 1, 2020 at 11:52 AM Nicolas Cadieux
>>>>> <njacadieux.gitlab at gmail.com <mailto:njacadieux.gitlab at gmail.com>>
>>>>> wrote:
>>>>> Hi,
>>>>> Looking at it now. I see what you see. I will try a few things.
>>>>> Nicolas
>>>>> On 2020-12-01 11:42 a.m., Alberto Vavassori wrote:
>>>>>> Hi Nicolas,
>>>>>> thank you for the answer. I send the raster that I am
>>>>>> interested in.
>>>>>> Alberto
>>>>>> *Da:*Nicolas Cadieux <njacadieux.gitlab at gmail.com>
>>>>>> *Inviato:* martedì 1 dicembre 2020 17:40
>>>>>> *A:* Alberto Vavassori <alberto.vavassori at polimi.it>
>>>>>> <mailto:alberto.vavassori at polimi.it>
>>>>>> *Cc:* qgis-user at lists.osgeo.org
>>>>>> <mailto:qgis-user at lists.osgeo.org>
>>>>>> *Oggetto:* Re: [Qgis-user] Importing a raster into a Geopackage
>>>>>> Hi,
>>>>>> Send a sample data set if you can't figure it out.
>>>>>> Nicolas
>>>>>> On 2020-12-01 10:35 a.m., Nicolas Cadieux wrote:
>>>>>> Hi,
>>>>>> Perhaps this can help:
>>>>>> https://gdal.orgdrivers/raster/gpkg.html
>>>>>> <https://gdal.orgdrivers/raster/gpkg.html>
>>>>>> “Various kind of input datasets can be converted to
>>>>>> GeoPackage raster :
>>>>>> ·Single band grey level
>>>>>> ·Single band with R,G,B or R,G,B,A color table
>>>>>> ·Two bands: first band with grey level, second band with
>>>>>> alpha channel
>>>>>> ·Three bands: Red, Green, Blue
>>>>>> ·Four band: Red, Green, Blue, Alpha
>>>>>> GeoPackage rasters only support Byte data type.”
>>>>>> My guess is that if the original raster does not
>>>>>> correspond to one of the categories above, it will be
>>>>>> converted to the closest format.
>>>>>> Nicolas Cadieux
>>>>>> https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
>>>>>> Le 1 déc. 2020 à 09:58, Alberto Vavassori
>>>>>> <mailto:alberto.vavassori at polimi.it> a écrit :
>>>>>> Hello everybody. I have an issue regarding the
>>>>>> Geopackage format. I have tried to import a
>>>>>> singleband raster file (it represents the land cover,
>>>>>> thus every pixel has a single integer value
>>>>>> corresponding to the land cover class), but this
>>>>>> operation seems to modify the raster characteristics:
>>>>>> the raster becomes a 4-bands raster and the pixels
>>>>>> values change accordingly (basically, the original
>>>>>> raster is saved in the Geopackage as an RGB image).
>>>>>> It seems to be a bug of QGIS. I have also tried to
>>>>>> use GDAL translate through the processing toolbox of
>>>>>> QGIS to convert the TIFF file to a Geopackage file,
>>>>>> but the result is the same.
>>>>>> Has anybody faced this problem? May anybody suggest a
>>>>>> way to work this problem out?
>>>>>> Thank you.
>>>>>> Alberto
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> <mailto:Qgis-user at lists.osgeo.org>
>>>>>> List info:
>>>>>> https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>>> Unsubscribe:
>>>>>> Nicolas Cadieux
>>>>> Nicolas Cadieux
>>>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe:
>>>> Nicolas Cadieux
>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Kirk Schmidt, MScF, BScF, RPF
>>> General Manager
>>> Nortek Resource Solutions Inc.
>>> RR # 1
>>> Thorburn, NS
>>> B0K 1W0
>>> Tel (902) 922.3607
>>> Email:kirk at nortekresources.com
>>> Web:www.nortekresources.com
>> Nicolas Cadieux
> General Manager
> RR # 1
> Thorburn, NS
> B0K 1W0
> Tel (902) 922.3607
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201201/4f6b8fe6/attachment-0001.html>
