[Qgis-user] Qgis-user Digest, Vol 178, Issue 5
Thayer Young thayeray at yahoo.com
Tue Dec 1 11:13:10 PST 2020
 There is also a Translate tool in the Processing Toolbox: Vector Geometry. That will do this operation on the entire file.
The tool is named for the linear algebra operation, and is not to be confused with  gdal_translate for reprojecting features (Translate (convert format)).
-Thayer
    On Tuesday, December 1, 2020, 01:58:58 PM EST, qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org> wrote:
Date: Tue, 1 Dec 2020 13:28:37 -0500
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Move polyline objects by set distance
Message-ID:
    <CAKaP4zcR7+CaDXNAa4Bx95Nm5dyfivWH05mWirXWULkp3gwZFQ at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
I have several polyline objects (hundreds) that I want to move on the map
by a short distance (3ft to the N, S, E, or W) in a cardinal type
direction.
I see the Move Objects tool in QGIS 3 but that doesn't allow me to specify
a distance.  I have used the Offset tool in the QAD plugin to create
parallel lines but that is very tedious and creates a copy of the object.
Is there a way to select a bunch of objects and just move them in one
direction or another by x # of feet?
Thanks!
*Ryan Peel*
Date: Tue, 1 Dec 2020 13:55:34 -0500
To: Ryan Peel <ryanpeel at gmail.com>
Cc: Qgis List <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Move polyline objects by set distance
Message-ID:
    <CAED_52rR=_XktqbwDfSwpVpierSNV7Zons9DgkYZwPJnb_WPKg at mail.gmail.com>
Ryan,
The advanced digitizing panel allows you to use the move tool and input a
specific distance (use the "d" shortcut). Here is some documentation:
https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#move-feature-s
-Sebastian
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201201/a2434f8d/attachment.html>
